Access to Component "File Properties" Through Assembly & Drawing Without Opening the Component
Posted: Tue Mar 05, 2024 10:39 am
Hello everyone,
Basically a macro for the subject says. I searched the forum library but could not find something similar.
I have Custom Properties setup which is great but it does not work in drawings environment
This forces me to switch back & forth a lot when I want to change properties of a component; say description, finishing note, etc.
Ideally precondition would be to pre-select an entity of the component from graphics view (for both assembly & drawings).
It'd be nice if you can select the component from BOM in drawing environment and the macro still works.
Thank you in advance!
Vahid
![cant..believe... o[](./images/smilies/brickhead.gif)
Vahid
