Date change macro
TTevolve
x 84
x 159
Date change macro
Unread post by TTevolve »
Date anyone have a macro that will change the date custom property for all parts in an assembly?
I love doing pack and go to copy an assembly and renumber it, but all the date custom properties need to get updated to the current date. I was hoping someone else has a macro that would update them all.
x 431
x 447
Re: Date change macro
TTevolve
x 84
x 159
gupta9665 wrote: Thu Mar 07, 2024 12:07 pm viewtopic.php?t=2578
I use that one all the time and it works great, the difference is I just want to enter the date, say 03/07/2024 and it changes all of them to that date.
The issue I have is sometimes the dates are not all the same if I did different parts on different days, so entering the value I want to change doesn't work. I would like it to just change every date custom property in each part to the date entered in the box.
x 431
x 447
Can you share one sample file to understand?
TTevolve
x 84
x 159
Every part and sub-assembly in an assembly has a "Date" custom property. When I do a pack & Go to make a new version they do not update, and they can be different vales (ie. The screenshot below has 11/17/2023 as the date on one part, but the other part has 12/01/2023). I want the macro to change all the date custom properties on each part and sub assembly in the assembly to change to the date I input in the macro.
This part M-247-A has a date of 11/17/2023
This part M-247-A-B1 has a date of 12/01/2023
After I did the pack & go and created these parts as part of the new assembly I got to go in and change the date on each one, some assembly's have 30 or 40 parts where I have to open each one and change the date to 03/08/2024.
x 431
x 447
The macro I have shared above should work OK.
Did you changed the number in below line to Date?
cpm.Add3 "Number", swCustomInfoText, mValue, 1
