administrative image customized machine configuration
Posted: Wed Mar 13, 2024 3:11 pm
2023 SP5
I am on the verge of deployment and I am making the last adjustments and checks on our admin image.
I have multiple deployment groups and SOME machine inside one of them had the toolbox customized to a different path. so i tried to RMB those machines and force their group settings back. it seems to temporary work, but if you press ok an close the admin image option editor and open it again the customization is still there for those machines... I also tried to RMB the group those machines belongs to and force the group settings on them and it was the same behavior: the customization is not overwritten.
the only workaround that worked is to manually set the toolbox location for each customized machine to match their group setting. In this way those machines match their group default and their settings are saved.
be careful and check ALL your machine settings before deployment.
