Text justification
Bryan O
x 17
x 37
Text justification
Unread post by Bryan O »
I'm playing with my title block layouts and I cant figure out how to Center/Center justify the text in a given space.
Any tips
by Bryan O » Fri Apr 19, 2024 11:17 am
OK It is center top justifying!
But it is also doing something interesting. It is recognizing and NOT recognizing spaces!
It is breaking the name "ConfigurationConfiguration Configuration Configuration" into
n ConfigurationConfiguration"
That is fine. I can live with that.
Thanks for your help!
x 2364
x 2013
Re: Text justification
Bryan O wrote: Thu Apr 18, 2024 3:46 pm I'm playing with my title block layouts and I cant figure out how to Center/Center justify the text in a given space.
Any tips
The "bounding box" of the text has to have it's center positionned at the center of the rectangle you want it centered at.
Bryan O
x 17
x 37
AlexLachance wrote: Thu Apr 18, 2024 3:59 pm The "bounding box" of the text has to have it's center positioned at the center of the rectangle you want it centered at.
In the attached images you can see the bounding box IS center/center but the resulting text is NOT.
I'm at a loss.
I have tried anchoring the box and that doesn't help....
x 2364
x 2013
That's odd, it seems to works for us
Bryan O
x 17
x 37
Do you put them in as a text field or note?
x 2364
x 2013
Bryan O wrote: Fri Apr 19, 2024 8:31 am Do you put them in as a text field or note?
I'm not quite sure I understand the distinction..?
Bryan O
x 17
x 37
I'm not sure there is a difference! LOL
x 877
Any tips
Can you upload your template?
Bryan O
x 17
x 37
For some reason it would not allow me to attach it as a .drwdot so I changed the extension to .txt.
TEST B SHEET FORMAT.txt
(71.38 KiB) Downloaded 79 times
Bryan O
x 17
x 37
x 220
Unread post by Dwight »
Bryan O wrote: Fri Apr 19, 2024 11:17 am It is recognizing and NOT recognizing spaces!
The "n" dropped off because it didn't fit in the width of your text box and there was no space before it to use as a break. Make the character size smaller or the box bigger, and it will break on the first space.
