Howdy
I have a part template with some sketch dimensions Marked for Drawing, but they are not inserting when I put that part into a drawing view.
Using the same drawing template, other parts with dims Marked for Drawing are auto-inserting the dimensions, but not this one.
Is there some sort of part document setting that I'm not thinking of?
SW 2022
Marked Dims not inserting in Drawing
- x 2361
- x 2011
Re: Marked Dims not inserting in Drawing
Only setting I'm aware of to use these is the ones inside the view commands but we don't really use marked dims.
- x 810
- x 978
Do you have this checked for that file?
(and it only works on view CREATION)
Once the view is created, you then need to use Insert --> Model Items
