Renaming a Mate with VBA
timied07
Unread post by timied07 »
I have been working on some mate macros and at the point that I think we need to rename some of the mates so they can still be easily located / alignment flipped with the macros after the assemblies are being built up.
I have access the mates and pull their paramteres, but I have not found a way to change the name. I have tried several things, but also feel I have exhausted the help files and google searches.
Thanks in advance!
Answers: 21
x 410
x 430
Re: Renaming a Mate with VBA
Use swFeature.GetTypeName2 to get if the type is Mate, and then use swFeature.Name to rename the mates.
timied07
Thanks, I'm definitely getting closer!
The Immediate Window shows the new name after running the macro:
However the feature tree in SolidWorks still shows the original name:
How do I push the name update back to SolidWorks?
RonE
x 17
x 29
Unread post by RonE »
Try UpdateFeatureTree Method (IFeatureManager) -> https://help.solidworks.com/2022/englis ... eTree.html
Answers: 21
x 410
x 430
timied07 wrote: Sun Jun 23, 2024 3:13 pm
Try force rebuild to reflect the new names.
timied07
I tried force rebuild and update feature tree, see attached screenshot of code:
Here is the relevant snippet from the Immediate Window
There is still no change in the Feature Tree in SolidWorks UI
Unsure if it makes a difference, but I'm running SW Student Edition 2023 SP 2.1
Answers: 21
x 410
x 430
Can you please share the complete macro to debug?
timied07
Yes, I'll post it a bit later on. Thanks
Answers: 27
x 257
x 432
This macro I wrote to test this works. It renames every mate in the mates folder by adding "_NEW" to the end of the name. No need to update the feature tree via rebuild or anything (2024 SP5)
Option Explicit
    Dim swModel As ModelDoc2
    Dim swFeature As Feature
    Set swModel = swApp.ActiveDoc
    If swModel Is Nothing Then Exit Sub
    If swModel.GetType <> swDocumentTypes_e.swDocASSEMBLY Then Exit Sub
    Debug.Print swModel.GetTitle
    Set swFeature = swModel.FirstFeature
    While Not swFeature Is Nothing
        Dim typeName As String
        typeName = swFeature.GetTypeName2
        Debug.Print typeName
        If typeName = "MateGroup" Then
            Dim swSubFeat As Feature
            Set swSubFeat = swFeature.GetFirstSubFeature
            While Not swSubFeat Is Nothing
                typeName = swSubFeat.GetTypeName2
                Debug.Print "  " + typeName
                swSubFeat.Name = swSubFeat.Name + "_NEW"
                Debug.Print "  New Name: " + swSubFeat.Name
                Set swSubFeat = swSubFeat.GetNextSubFeature
            Wend
        Set swFeature = swFeature.GetNextFeature
    Wend
timied07
Here is my macro, it is quite ugly at the moment after trying a lot of things...sorry in advance
Option Explicit
Function SelectMateEntity(swApp As SldWorks.SldWorks, swModel As SldWorks.ModelDoc2, swMateEnt As SldWorks.MateEntity2, nMark As Long) As Boolean
    Dim swEnt As SldWorks.Entity
    Dim swSelData As SldWorks.SelectData
    Dim bRet As Boolean
    Select Case swMateEnt.ReferenceType
        Case swMateEntity2ReferenceType_Point, _
                swMateEntity2ReferenceType_Line, _
                swMateEntity2ReferenceType_Circle, _
                swMateEntity2ReferenceType_Plane, _
                swMateEntity2ReferenceType_Cylinder, _
                swMateEntity2ReferenceType_Sphere, _
                swMateEntity2ReferenceType_Cone, _
                swMateEntity2ReferenceType_SweptSurface
            Set swSelData = swSelMgr.CreateSelectData
            Set swEnt = swMateEnt.Reference
            swSelData.Mark = nMark
            bRet = swEnt.Select4(True, swSelData)
            SelectMateEntity = bRet
            Exit Function
        Case swMateEntity2ReferenceType_Set, _
                swMateEntity2ReferenceType_MultipleSurface, _
                swMateEntity2ReferenceType_GenSurface, _
                swMateEntity2ReferenceType_Ellipse, _
                swMateEntity2ReferenceType_GeneralCurve, _
                swMateEntity2ReferenceType_UNKNOWN
        Case Else
    End Select
    SelectMateEntity = False
End Function
Sub main2()
    'On Error Resume Next
    Dim swComp As SldWorks.Component2
    Dim swAssy As AssemblyDoc
    Dim swMates() As SldWorks.Feature
    Dim isInit As Boolean
    'inInit = False
    Dim X As Integer
    Dim i As Integer
    Dim swMateGroupFeat As SldWorks.Feature
    Dim featIndex As Integer
    featIndex = 0
    Dim arrayMates As Variant
    Dim swMate2 As SldWorks.Mate2
    Dim swMateEntity As SldWorks.MateEntity2
    Dim testComp As SldWorks.Component2
    Dim nNewMateAlign As swMateAlign_e
    Dim ErrorLong As Long
    Dim swMateEdit As Mate2
    Dim instance As IAssemblyDoc
    Set swAssy = swApp.ActiveDoc
    Set instance = swApp.IActiveDoc
    Dim nNumMateEnt As Long
    Dim swMateEnt() As SldWorks.MateEntity2
    Dim vMateEntPar As Variant
    Dim bRet As Variant
    Dim mateCount As Integer
    Dim instance2 As IFeatureManager
    Dim swFeatMgr As SldWorks.FeatureManager
    If Not swAssy Is Nothing Then
        Set swSelMgr = swAssy.SelectionManager
        Set swComp = swSelMgr.GetSelectedObjectsComponent3(1, -1)
        If Not swComp Is Nothing Then
            Debug.Print swComp.GetPathName
            Debug.Print swComp.Name2
            swComp.Select4 False, Nothing, False
            arrayMates = swComp.GetMates
            mateCount = UBound(arrayMates) - LBound(arrayMates)
            If mateCount = 1 Then
                For X = LBound(arrayMates) To UBound(arrayMates)
                    'If arrayMates(X).Type = 0 Then
                        Set swMate2 = arrayMates(X)
                        nNumMateEnt = swMate2.GetMateEntityCount
                        Debug.Print "Type::    " & swMate2.Type
                        Debug.Print "Mate Name::   " & arrayMates(X).Name
                        Debug.Print "Alignment::   " & swMate2.Alignment
                        Debug.Print "Entity Count::    " & nNumMateEnt
                        Debug.Print "Test::     " & Left(swComp.Name, InStr(swComp.Name, "-") - 1) & "+" & arrayMates(X).Name
                        ReDim swMateEnt(nNumMateEnt)
                        For i = 0 To nNumMateEnt - 1
                            Set swMateEnt(i) = swMate2.MateEntity(i)
                            Set swComp = swMateEnt(i).ReferenceComponent
                            vMateEntPar = swMateEnt(i).EntityParams
                            Debug.Print "      RefType(" & i & ")   = " & swMateEnt(i).ReferenceType
                            Debug.Print "        Component          = " & swComp.Name2 & " (" & swComp.ReferencedConfiguration & ") --> " & swComp.GetPathName
                            Debug.Print "        Point              = (" & vMateEntPar(0) * 1000# & ", " & vMateEntPar(1) * 1000# & ", " & vMateEntPar(2) * 1000# & ") mm"
                            Debug.Print "        Vector             = (" & vMateEntPar(3) & ", " & vMateEntPar(4) & ", " & vMateEntPar(5) & ")"
                            Debug.Print "        Radius 1           = " & vMateEntPar(6) * 1000# & " mm"
                            Debug.Print "        Radius 2           = " & vMateEntPar(7) * 1000# & " mm"
                        Next i
                        'boolstatus = swAssy.Extension.SelectByID2(arrayMates(X).Name, "MATE", 0, 0, 0, False, 0, Nothing, 0)
                        If swMateAlignALIGNED = swMate2.Alignment Then
                            nNewMateAlign = swMateAlignANTI_ALIGNED
                            Debug.Print "Was Aligned"
                        Else
                            If swMateAlignANTI_ALIGNED = swMate2.Alignment Then
                                nNewMateAlign = swMateAlignALIGNED
                                Debug.Print "Was Anti-Aligned"
                            Else
                                ' closest alignment, so changing alignment does not make sense
                                Debug.Assert swMateAlignCLOSEST = swMate2.Alignment
                                Exit Sub
                        swAssy.ClearSelection2 True
                            bRet = SelectMateEntity(swApp, swAssy, swMateEnt(i), 1)
                        Next i
                        'bRet = swFeat.Select2(True, 0)
                        bRet = swMate2.Select2(True, 0)
                        swAssy.EditMate3 swMate2.Type, nNewMateAlign, True, 0, 0, 0, 0, 0, 0, 0, 0, False, True, 0, ErrorLong
                        'Trying to rename mate
                        Debug.Print "swMate2.GetTypeName2 :   " & swMate2.GetTypeName2
                        Debug.Print "Read name swMate2.Name :   " & swMate2.Name
                        arrayMates(X).Name Left(swComp.Name, InStr(swComp.Name, "-") - 1) & "+" & arrayMates(X).Name
                        Debug.Print "After changing name swMate2.Name :   " & swMate2.Name
                    'End If
                Next
            Else                          'If more than 2 mates
                Exit Sub
    'trying to rename outside of if statement just to simplify
    Debug.Print "Before Pause aka stop command"
    Stop
    Set swFeatMgr = swModel.FeatureManager
    swFeatMgr.UpdateFeatureTree
    Debug.Print "After Resuming the stop and running swFeatMgr.UpdateFeatureTree"
    Debug.Print "Mate name should show as:    " & swMate2.Name
    'end of rename attempts
    bRet = swAssy.EditRebuild3
    bRet = swModel.ForceRebuild3(True)
What I am trying to do is flip the mates of a component that is selected in the assembly; and rename the mates so I can build off of the mates later if needed (example: need to unflip/reset these mates, or want to skip these mates if flipping other mates that reference this component, etc.)
Alex, I tried your macro as a copy and paste and it renamed flawlessly; however I couldn't figure out why that worked and mine is not. Still need to figure out how to integrate the solutions together. It did rename ALL mates in the assembly, which is not what I'm after, trying to target very specific mates.
Close...........
Answers: 21
x 410
x 430
Are you missing "=" in this line
arrayMates(X).Name =  Left(swComp.Name, InStr(swComp.Name, "-") - 1) & "+" & arrayMates(X).Name
Answers: 27
x 257
x 432
It looks like AssemblyDoc::EditMate3 is obsolete and no longer supported. I did further testing with the IMate2 interface and it appears you can cast it to a IFeature object and then rename it.
timied07
That didn't seem to make a difference.
Here is my setup:
1. Before execution of macro, click a face of the bearing. (You can see the highlighted line in the macro includes the "=" now
2. Here is the result from the execution
timied07
Alex,
Thanks. I'm not following what you are saying. What do you mean by cast?
Answers: 27
x 257
x 432
Would changing your line to set the name to include an explicit cast like this make a difference?
Dim mateFeature As Feature
Set mateFeature = arrayMates(x)
mateFeature.Name = Left(swComp.Name, InStr(swComp.Name, "-") - 1) & "+" & arrayMates(X).Name
Edit: Casting is essentially telling the code to treat this as a specific type. VBA gets a little odd when trying to do this but hopefully it should work.
timied07
Didn't seem to make a difference
timied07
I do think I'm on to something by combining my macro with your macro Alex. I need to try to compare the list of mate names that I have identified against all the the mates n the assembly and rename if they match.
timied07
I think I have it working. It is likely not the most efficient way to do it, but it seems to work for now.
Here is the code, needs some cleanup for sure...
Option Explicit
    Dim bRet As Boolean
            Exit Function
        Case Else
    End Select
End Function
Sub Beta()
    'inInit = False
    Dim X As Integer
    Dim i As Integer
    featIndex = 0
    Dim bRet As Variant
                        Next i
                        Else
                            Else
                                Exit Sub
                        Next i
                        'arrayMates(X).Name Left(swComp.Name, InStr(swComp.Name, "-") - 1) & "+" & arrayMates(X).Name
                        Debug.Print arrayMates(X).Name
                    'End If
                Next
                Exit Sub
        'Trying to integrate AlexB
            Dim typename As String
            typename = swFeature.GetTypeName2
            If typename = "MateGroup" Then
                        If swSubFeat.Name = arrayMates(X).Name Then
                            swSubFeat.Name = swSubFeat.Name & "+Bearing"
                    Next
                Wend
        Wend
timied07
Huge thanks for helping me troubleshoot this and get a working solution!
I want to run through this macro in use a bit before I mark it solved, but I think I have it working; just want more testing and tested on a different computer to verify.
Should I be marking AlexB's post as correct answer?
