Solidworks configurations copy derived configurations together in the same part
Ömür Tokman
x 995
x 347
Unread post by Ömür Tokman »
Hi Guys,
Solidworks configurations copy derived configurations together in the same part.
I'm looking for an easy way to do this.
As you can see in the picture below, I am creating the Metric configurations of a bolt, (manually)
I do not want to use Excel (table).
For example, when I want to create an M 8, I create the configuration and its individual sub-configurations manually. I thought of copying and pasting a configuration with its sub-configurations in the same part and changing its names and dimensions, but there is no such option.
There must be something I do not know!
I kindly request your support for a practical solution.
https://grabcad.com/omur.tokman-1/models
by DanPihlaja » Mon Aug 05, 2024 9:18 am
Ömür Tokman wrote: Sat Aug 03, 2024 7:06 am Hi Guys,
Just hit CTRL C on the parent configuration, and then CTRL V on the top level. It copies the parent config and all downstream configs.
Answers: 26
x 821
x 1006
Re: Solidworks configurations copy derived configurations together in the same part
Ömür Tokman
x 995
x 347
DanPihlaja wrote: Mon Aug 05, 2024 9:18 am Just hit CTRL C on the parent configuration, and then CTRL V on the top level. It copies the parent config and all downstream configs.
Thanks Dan,
I will try it tomorrow and get back to you.
x 2311
x 1947
Unfortunately it doesn't copy any exploded views attached to the configuration. :(
Answers: 26
x 821
x 1006
SPerman wrote: Mon Aug 05, 2024 3:48 pm Unfortunately it doesn't copy any exploded views attached to the configuration. :(
Ahh. I didn't test it far enough....
UU
x 2311
x 1947
It would be really helpful if there were a way to copy exploded views.
Answers: 26
x 821
x 1006
SPerman wrote: Mon Aug 05, 2024 4:12 pm It would be really helpful if there were a way to copy exploded views.
Actually, you can.
While the exploded views don't copy when you copy/paste the parent config, you can select the exploded view itself and copy and paste it to a new config.
You just have to do them individually.
(I am using SW 2022, SP4)
x 2311
x 1947
I could swear I tried that in the past without success. Good to know how to make it work.
Ömür Tokman
x 995
x 347
I tried many things but I don't know why I didn't try this. o[
Yes it is, it works. Thanks Dan.
