How To Add QTY to a Note? Is it Possible?
DanBovinich
x 4
x 15
Unread post by DanBovinich »
I want to make a note, that when attached to an item in an assembly drawing, will give this result:
Qty Custom property 1 Custom property 2
For Example:
3X MCMASTER 90128A266
I can easily make a note with the custom properties, but can't figure out how to add a QTY to the note.
I was able to do this with a Balloon, but has undesirable traits.
Thank you for any help you may give me,
Dan B.
Thank you,
Dan B.
x 790
x 946
Re: How To Add QTY to a Note? Is it Possible?
I am not sure that you can do it with a note (I cannot figure out quantity in a note without linking the note to a balloon). But you can do it with stacked balloons (might need to format them)
x 790
x 946
OK, you can also link a note to a table cell.
Just select the "Link Table Cell" button and select the table cells that you want linked to it.
DanBovinich
x 4
x 15
Thank you Dan, I had managed to do that, BUT, the note length can't be wrapped/shortened. That was the "undesirable trait" I was speaking about.
I want to make a second note with the full description of the fastener. Without the ability to "wrap" the text, I won't be able to fit the notes on the dwg...
o[
see attached image.
Thanks,
Dan B.
x 790
x 946
DanBovinich wrote: Mon Aug 05, 2024 3:49 pm Thank you Dan, I had managed to do that, BUT, the note length can't be wrapped/shortened. That was the "undesirable trait" I was speaking about.
o[
see attached image.
Thanks,
Dan B.
Well, you can wrap the note, you just cannot wrap it inside the context of the link.
So you can wrap between 3 links, but if 1 link is really long, then it will take up 1 line and cannot be wrapped. Which is probably what you are referring to.
DanBovinich
x 4
x 15
Hence, why I wanted to use the annotation route.... (that has the ability to wrap the long description)
We can always hope SW 2026 makes a fix for this....
Dan B.
Thank you,
Dan B.
