Batch export to Iges/Step based on Display States
Bradfordzzz
x 347
x 210
Unread post by Bradfordzzz »
Has anyone seen a macro that would be able to batch export the items in each display state?
I would like them to be in a separate iges and step file and name the files base on the assembly and display state name.
This might already exist, I just haven't been able to find one yet.
Is this even possible?
Thanks.
Mark
by Stefan Sterk » Wed Aug 07, 2024 7:39 am
Bradfordzzz wrote: Wed Aug 07, 2024 6:41 am Thanks Stefan! It looks like this one will only export configurations .. but not display states.
I have seen a few of these, but cant find any that will work with display states.
Like a said, you would need to make some changes to the code.
Use the following line for for OUT_NAME_TEMPLATES
OUT_NAME_TEMPLATES = Array("<_FileName_>_<_DispName_>.stp", "<_FileName_>_<_DispName_>.igs")
And add some lines to the ResolveToken function as is shown below.
Function ResolveToken(token As String, model As SldWorks.ModelDoc2) As String
	Const DISP_NAME_TOKEN As String = "_DispName_"
	Select Case LCase(token)
		Case LCase(DISP_NAME_TOKEN)
			ResolveToken = model.ConfigurationManager.ActiveConfiguration.GetDisplayStates()(0)
	End Select
End Function
I haven't tested it myself, but just let me know if you run into some issues.
EDIT: Made the changes my self, see code below.
'Copyright(C) 2024 Xarial Pty Limited
'Reference: https://www.codestack.net/solidworks-api/import-export/export-multi-formats/
'License: https://www.codestack.net/license/
Const ALL_CONFIGS As Boolean = False
Const OUT_FOLDER As String = ""
Const STEP_VERSION As Long = 214 '203 or 214
Const PDF_3D As Boolean = False 'True to export 3D PDF
Dim OUT_NAME_TEMPLATES As Variant
    Dim origStepVersion As Long
    'OUT_NAME_TEMPLATES = Array("PDFs\<_FileName_>_<_ConfName_>_<PartNo>.pdf", "IMGs\<_FileName_>_<_ConfName_>_<PartNo>.jpg")
try_:
    On Error GoTo catch_
    Set swModel = swApp.ActiveDoc
    If swModel Is Nothing Then
        Err.Raise vbError, "", "Please open document"
    If swModel.GetPathName() = "" Then
        Err.Raise vbError, "", "Please save the model"
    Dim outFolder As String
    If Not TryGetOutDirFromArguments(outFolder) Then
        outFolder = OUT_FOLDER
    ReadOptions origStepVersion
    SetupOptions STEP_VERSION
    ExportFile swModel, OUT_NAME_TEMPLATES, ALL_CONFIGS, outFolder
    GoTo finally_
catch_:
    swApp.SendMsgToUser2 Err.Description, swMessageBoxIcon_e.swMbStop, swMessageBoxBtn_e.swMbOk
finally_:
    SetupOptions origStepVersion
Sub ReadOptions(ByRef stepVersion As Long)
    stepVersion = swApp.GetUserPreferenceIntegerValue(swUserPreferenceIntegerValue_e.swStepAP)
Sub SetupOptions(stepVersion As Long)
    If False = swApp.SetUserPreferenceIntegerValue(swUserPreferenceIntegerValue_e.swStepAP, stepVersion) Then
        Err.Raise vbError, "", "Failed to set Step Export version to " & stepVersion
Sub ExportFile(model As SldWorks.ModelDoc2, vOutNameTemplates As Variant, allConfigs As Boolean, outFolder As String)
    Dim i As Integer
    Dim j As Integer
    Dim curConf As String
    If model.GetType() = swDocumentTypes_e.swDocDRAWING Then
        Dim swDraw As SldWorks.DrawingDoc
        Set swDraw = model
        curConf = swDraw.GetCurrentSheet().GetName
    Else
        curConf = model.ConfigurationManager.ActiveConfiguration.Name
    Dim vConfs As Variant
    If allConfigs Then
            vConfs = model.GetSheetNames()
        Else
            vConfs = model.GetConfigurationNames()
    Else
        Dim sConfs(0) As String
        sConfs(0) = curConf
        vConfs = sConfs
    For i = 0 To UBound(vConfs)
            curConf = swDraw.ActivateSheet(CStr(vConfs(i)))
        Else
            model.ShowConfiguration2 CStr(vConfs(i))
        For j = 0 To UBound(vOutNameTemplates)
            Dim errs As Long
            Dim warns As Long
            Dim outNameTemplate As String
            outNameTemplate = vOutNameTemplates(j)
            Dim outFilePath As String
            outFilePath = ComposeOutFileName(outNameTemplate, model, outFolder)
            Dim outDir As String
            outDir = Left(outFilePath, InStrRev(outFilePath, "\"))
            CreateDirectories outDir
            Dim swExportData As Object
            If LCase(GetExtension(outFilePath)) = LCase("pdf") Then
                Dim swExportPdfData As SldWorks.ExportPdfData
                Set swExportPdfData = swApp.GetExportFileData(swExportDataFileType_e.swExportPdfData)
                swExportPdfData.ViewPdfAfterSaving = False
                swExportPdfData.ExportAs3D = PDF_3D
                Set swExportData = swExportPdfData
            Else
                Set swExportData = Nothing
            If False = model.Extension.SaveAs(outFilePath, swSaveAsVersion_e.swSaveAsCurrentVersion, swSaveAsOptions_e.swSaveAsOptions_Silent + swSaveAsOptions_e.swSaveAsOptions_Copy, swExportData, errs, warns) Then
                Err.Raise vberrror, "", "Failed to export to " & outFilePath
        Next
    Next
        curConf = swDraw.ActivateSheet(curConf)
    Else
        model.ShowConfiguration2 curConf
Function ComposeOutFileName(template As String, model As SldWorks.ModelDoc2, outFolder As String) As String
    Dim regEx As Object
    Set regEx = CreateObject("VBScript.RegExp")
    regEx.Global = True
    regEx.IgnoreCase = True
    regEx.Pattern = "<[^>]*>"
    Dim regExMatches As Object
    Set regExMatches = regEx.Execute(template)
    Dim i As Integer
    Dim outFileName As String
    outFileName = template
    For i = regExMatches.Count - 1 To 0 Step -1
        Dim regExMatch As Object
        Set regExMatch = regExMatches.Item(i)
        Dim tokenName As String
        tokenName = Mid(regExMatch.Value, 2, Len(regExMatch.Value) - 2)
        outFileName = Left(outFileName, regExMatch.FirstIndex) & ResolveToken(tokenName, model) & Right(outFileName, Len(outFileName) - (regExMatch.FirstIndex + regExMatch.Length))
    Next
    ComposeOutFileName = ReplaceInvalidPathSymbols(GetFullPath(model, outFileName, outFolder))
End Function
Function ReplaceInvalidPathSymbols(path As String) As String
    Const REPLACE_SYMB As String = "_"
    Dim res As String
    res = Right(path, Len(path) - Len("X:\"))
    Dim drive As String
    drive = Left(path, Len("X:\"))
    Dim invalidSymbols As Variant
    invalidSymbols = Array("/", ":", "*", "?", """", "<", ">", "|")
    Dim i As Integer
    For i = 0 To UBound(invalidSymbols)
        Dim invalidSymb As String
        invalidSymb = CStr(invalidSymbols(i))
        res = Replace(res, invalidSymb, REPLACE_SYMB)
    Next
    ReplaceInvalidPathSymbols = drive + res
End Function
    Const FILE_NAME_TOKEN As String = "_FileName_"
    Const CONF_NAME_TOKEN As String = "_ConfName_"
        Case LCase(FILE_NAME_TOKEN)
            ResolveToken = GetFileNameWithoutExtension(model.GetPathName)
        Case LCase(CONF_NAME_TOKEN)
                Set swDraw = model
                ResolveToken = swDraw.GetCurrentSheet().GetName
            Else
                ResolveToken = model.ConfigurationManager.ActiveConfiguration.Name
        Case Else
            Dim swCustPrpMgr As SldWorks.CustomPropertyManager
            Dim resVal As String
            resVal = ""
            If model.GetType() <> swDocumentTypes_e.swDocDRAWING Then
                Set swCustPrpMgr = model.Extension.CustomPropertyManager(model.ConfigurationManager.ActiveConfiguration.Name)
                swCustPrpMgr.Get2 token, "", resVal
            If resVal = "" Then
                Set swCustPrpMgr = model.Extension.CustomPropertyManager("")
            ResolveToken = resVal
    End Select
End Function
Function GetFileNameWithoutExtension(path As String) As String
    GetFileNameWithoutExtension = Mid(path, InStrRev(path, "\") + 1, InStrRev(path, ".") - InStrRev(path, "\") - 1)
End Function
Function GetExtension(path As String) As String
    GetExtension = Right(path, Len(path) - InStrRev(path, "."))
End Function
Function FileExists(filePath As String) As Boolean
    FileExists = Dir(filePath) <> ""
End Function
Sub CreateDirectories(path As String)
    Dim fso As Object
    Set fso = CreateObject("Scripting.FileSystemObject")
    If fso.FolderExists(path) Then
        Exit Sub
    CreateDirectories fso.GetParentFolderName(path)
    fso.CreateFolder path
Function GetFullPath(model As SldWorks.ModelDoc2, path As String, outFolder As String)
    GetFullPath = path
    If IsPathRelative(path) Then
        If Left(path, 1) <> "\" Then
            path = "\" & path
        If outFolder = "" Then
            Dim modelPath As String
            Dim modelDir As String
            modelPath = model.GetPathName
            modelDir = Left(modelPath, InStrRev(modelPath, "\") - 1)
            outFolder = modelDir
        Else
            If Right(outFolder, 1) = "\" Then
                outFolder = Left(outFolder, Len(outFolder) - 1)
        GetFullPath = outFolder & path
End Function
Function IsPathRelative(path As String)
    IsPathRelative = Mid(path, 2, 1) <> ":" And Not IsPathUnc(path)
End Function
Function IsPathUnc(path As String)
    IsPathUnc = Left(path, 2) = "\\"
End Function
Function TryGetOutDirFromArguments(ByRef outDir As String) As Boolean
try_:
    Dim macroRunner As Object
    Set macroRunner = CreateObject("CadPlus.MacroRunner.Sw")
    Dim param As Object
    Set param = macroRunner.PopParameter(swApp)
    Dim vArgs As Variant
    vArgs = param.Get("Args")
    outDir = CStr(vArgs(0))
    TryGetOutDirFromArguments = True
    GoTo finally_
catch_:
    TryGetOutDirFromArguments = False
finally_:
End Function
Stefan Sterk
x 60
x 83
Re: Batch export to Iges/Step based on Display States
Unread post by Stefan Sterk »
Hi Bradrordzzz,
Have you seen this macro from codestack.net?
Only need some changes, so it adds the name of the current/active display state to the name.
Bradfordzzz
x 347
x 210
Stefan Sterk wrote: Wed Aug 07, 2024 6:19 am Hi Bradrordzzz,
Stefan Sterk
x 60
x 83
	End Select
End Function
try_:
    GoTo finally_
catch_:
finally_:
    Dim i As Integer
    Dim j As Integer
        Set swDraw = model
    Else
    If allConfigs Then
        Else
    Else
        sConfs(0) = curConf
        vConfs = sConfs
        Else
            Dim errs As Long
            Dim warns As Long
            Else
        Next
    Next
    Else
    Dim regEx As Object
    regEx.Global = True
    Dim i As Integer
    Next
End Function
    Dim res As String
    Dim drive As String
    Dim i As Integer
    Next
End Function
                Set swDraw = model
            Else
        Case Else
            resVal = ""
            If resVal = "" Then
    End Select
End Function
End Function
End Function
End Function
    Dim fso As Object
        Exit Sub
    GetFullPath = path
            path = "\" & path
        Else
End Function
End Function
End Function
try_:
    Dim param As Object
    GoTo finally_
catch_:
finally_:
End Function
Bradfordzzz
x 347
x 210
Thank you so much Stefan!
This works perfectly for the "Default Display State", but its stops before it does any of the others.
In fact .. it would be better for us if it only did the other display state, and it skipped the Default Display state, because that would just be our working display state, and not have any particular features isolated. Its ok if it gets made .. i just can't see us ever needing it so it would likely just be redundant.
Are you able to help with this?
Thanks,
Mark
Stefan Sterk
x 60
x 83
Well, these are the changes you need to make to make that happen. These are just quick edits, so keep in mind that the code can still be optimized. But it will do the job. UU
Simply change the following line with in Main()
to
    ' ####### LOOP THROUGH DISPLAY STATES #########
    Dim vDispStates As Variant
    vDispStates = swModel.ConfigurationManager.ActiveConfiguration.GetDisplayStates
    Dim i As Integer
    For i = 0 To UBound(vDispStates) ' <---- CHANGE i = 0 to i = 1 if you wanna skip the active display state
        swModel.ConfigurationManager.ActiveConfiguration.ApplyDisplayState vDispStates(i)
    Next
    swModel.ConfigurationManager.ActiveConfiguration.ApplyDisplayState vDispStates(0)
If you wanna skip the active displaystate then make the changes to the following line as described within the line.
Here is the full code.
try_:
    Dim i As Integer
    Next
    GoTo finally_
catch_:
finally_:
    Dim i As Integer
    Dim j As Integer
        Set swDraw = model
    Else
    If allConfigs Then
        Else
    Else
        sConfs(0) = curConf
        vConfs = sConfs
        Else
            Dim errs As Long
            Dim warns As Long
            Else
        Next
    Next
    Else
    Dim regEx As Object
    regEx.Global = True
    Dim i As Integer
    Next
End Function
    Dim res As String
    Dim drive As String
    Dim i As Integer
    Next
End Function
                Set swDraw = model
            Else
        Case Else
            resVal = ""
            If resVal = "" Then
    End Select
End Function
End Function
End Function
End Function
    Dim fso As Object
        Exit Sub
    GetFullPath = path
            path = "\" & path
        Else
End Function
End Function
End Function
try_:
    Dim param As Object
    GoTo finally_
catch_:
finally_:
End Function
Bradfordzzz
x 347
x 210
Thank you very much for this. It does exactly what I was looking for.
Really appreciate you taking the time for this.
Mark
Bradfordzzz
x 347
x 210
ok ... this might be a big ask ... im really not sure. feel free to tell me to bugger off if it is.
Im just wondering if you might be able to modify this macro so that a selection box would pop up and allow you to select which display states you would want the macro to process? Is that doable?
Stefan Sterk
x 60
x 83
Bradfordzzz wrote: Fri Aug 09, 2024 10:26 am ok ... this might be a big ask ... im really not sure. feel free to tell me to bugger off if it is.
Yes that is possible.
1. Create a UserForm1
2. Add ListBox1 to UserFrom1
3. Add CommandButton1 to UserForm1
4. Copy and paste the following code under UserForm1.
UserFrom1
Option Explicit
Private Sub CommandButton1_Click()
    Me.Hide
Private Sub UserForm_Initialize()
    Me.Caption = "Display State - Batch Exporter"
    Me.Height = 247
    Me.Width = 200
    ListBox1.Top = 5
    ListBox1.Left = 5
    ListBox1.Width = 178
    ListBox1.Height = 180
    ListBox1.MultiSelect = fmMultiSelectExtended
    CommandButton1.Top = 188
    CommandButton1.Left = 5
    CommandButton1.Caption = "Start Export"
Private Sub UserForm_Terminate()
    ListBox1.Clear
And this code to your main module
Module...
try_:
    Dim vDispState As Variant
    For Each vDispState In vDispStates
        UserForm1.ListBox1.AddItem vDispState
    Next vDispState
    UserForm1.Show
    Dim i As Integer
    For i = 0 To UserForm1.ListBox1.ListCount - 1
        If UserForm1.ListBox1.Selected(i) = True Then
            Debug.Print UserForm1.ListBox1.List(i)
            swModel.ConfigurationManager.ActiveConfiguration.ApplyDisplayState UserForm1.ListBox1.List(i)
    Next i
    GoTo finally_
catch_:
finally_:
    Unload UserForm1
    Dim i As Integer
    Dim j As Integer
        Set swDraw = model
    Else
    If allConfigs Then
        Else
    Else
        sConfs(0) = curConf
        vConfs = sConfs
        Else
            Dim errs As Long
            Dim warns As Long
            Else
        Next
    Next
    Else
    Dim regEx As Object
    regEx.Global = True
    Dim i As Integer
    Next
End Function
    Dim res As String
    Dim drive As String
    Dim i As Integer
    Next
End Function
                Set swDraw = model
            Else
        Case Else
            resVal = ""
            If resVal = "" Then
    End Select
End Function
End Function
End Function
End Function
    Dim fso As Object
        Exit Sub
    GetFullPath = path
            path = "\" & path
        Else
End Function
End Function
End Function
try_:
    Dim param As Object
    GoTo finally_
catch_:
finally_:
End Function
Which should result in ⇩
Bradfordzzz
x 347
x 210
I have tried running the new macro, but when importing the userform, I get the following error.
UserForm1.log
Line 8: Property OleObjectBlob in UserForm1 had an invalid file reference.
Stefan Sterk
x 60
x 83
Bradfordzzz wrote: Fri Aug 09, 2024 11:49 am I have tried running the new macro, but when importing the userform, I get the following error.
UserForm1.log
I see. Got the same error when importing. Not sure why it's doing that. I have edited the post, you need to manualy add the UserForum.
Bradfordzzz
x 347
x 210
Stefan Sterk wrote: Sun Aug 11, 2024 11:04 am I see. Got the same error when importing. Not sure why it's doing that. I have edited the post, you need to manualy add the UserForum.
Your new macro works perfectly! Thanks so much Stefan. Really appreciated!!
