Maybe someone can tell me if my title block is pulling the wrong information.
Before I explain, I think all sheets of a drawing should have the same title/description. There are some I work with that think otherwise.
Here is what's happening.
I have a title block set up to pull the configuration name/description/rev from the part/assembly file.
When the sheet is copied to create a multi sheet drawing, the parent view configuration is change but the title block does not change.
EX: I have a part "TOP" with 2 configurations: "TOP-LAMINATE" & "TOP-GLASS"
I would like Sheet1 to read "TOP-LAMINATE" and Sheet2 to read "TOP-GLASS"
Am I pulling the incorrect information for this to happen?
Title block issues
Title block issues
You'll want to edit your Sheet2 properties and un-check this box and change the reference drawing view to the parent one on the current page you want to use.
Go to full post- DanPihlaja
- x 790
- x 946
Re: Title block issues
Do you have this checked on your template settings? (SW2022 SP4)
NO. That check box is cleared.
