Editing Config Specific Props from BOM question
loeb
x 39
x 10
Unread post by loeb »
I'm writing a macro that will iterate through a BOM and will edit configuration specific properties of parts/assemblies in the BOM. To be clear, I want to edit the part/assembly files themselves. This is a big step beyond anything I have written before and have a question.
I know how to traverse the bom and identify the components in each row using "swBOMTableAnn.GetComponents2". I think I then need to use "OpenDoc7" on each component so that I can then use "swCustPropMgr.Add3" to edit their configuration specific custom properties. Am I taking the correct approach?
Thank You
Answers: 28
x 266
x 444
Re: Editing Config Specific Props from BOM question
If you're in an assembly, then you don't necessarily have to call OpenDoc#. You can likely just get the ModelDoc2 from each Component2 interface and manage the custom properties without having to open/activate each child document.
If you manage to get some code together, I'm sure others in addition to myself would be happy to take a look to help you over some road blocks or improve anything.
loeb
x 39
x 10
AlexB,
I'm opening the parts/assemblies as I'm going through a drawing BOM.
I managed to get my code working today, much like I described. Now, to move them to the vault and check them in and figure out how the PDM API...
Thank you for your offer of help. I might just take that you up on that.
x 427
x 446
loeb wrote: Tue Sep 10, 2024 6:16 pm AlexB,
Please note that PDM API is not supported in Standard version. So you will need PDM professional in order to use the APIs.
