limit mate selection error
hi
i want to put limit mate between piston face and shell base
but it is giving me error
thank you
thank you
File is Attached.
Go to full post- Maha Nadarasa
- x 51
- x 48
Re: limit mate selection error
File is Attached.
- Limit mate selection.zip
- (615.42 KiB) Downloaded 68 times
- Ömür Tokman
- x 972
- x 328
Hi Maha How are you?
I did not encounter any problems.
the file is attached.
- files.rar
- (599.69 KiB) Downloaded 50 times
- x 2203
- x 1902
The errors are within your limits, have a look at your mate.
1 inch is the sliding you want
your minimum is 1 inch
your maximum is 1 inch
Switch one of the min/max to something else.
- Maha Nadarasa
- x 51
- x 48
@ Assis As
If you can solve your issue it is okay.
- Ömür Tokman
- x 972
- x 328
Maha, I can't understand. did you solve your problem
- x 2203
- x 1902
It wasn't Maha that had a problem, it was Assis As, so Maha is asking if it is solved with our answers.
- Ömür Tokman
- x 972
- x 328
My bad English....
I'm still learning but learning a new language is really hard.![Smile :)](./images/smilies/icon_e_smile.gif)
thankyou maha working perfectly
yes i change , thank youAlexLachance wrote: ↑Fri Apr 16, 2021 8:11 am The errors are within your limits, have a look at your mate.
