How to unselect "Display sheet Format" in VBA
Jacomuller
x 36
x 5
Unread post by Jacomuller »
G'Day
I use a macro to insert a new custom size sheet in a Solidworks 2019 drawing. (I have created a custom template "TAG_MW_Single_View".) The macro work well and it sets all properties as required. The only thing missing is to deselect "Display sheet format". I have recorded macro when I do it manually and the code for that is:
Set Part = swApp.ActiveDoc
Part.ClearSelection2 True
boolstatus = Part.SetupSheet5("MW Sheet", 12, 12, 1, 20, False, "C:\SWDVault\Engineering\Z00 -
Solidworks\sheetformat\TAG_MW_Single_View.slddrt", 0.42, 0.297, "Default", False)
The "Part.ClearSelection2 True" is the code that clears the box, but if I use it in my code it does not work.
I have also tried "swDraw.SheetFormatVisible = False" and that use to work but for some reason it is not working anymore. I must have changed some code somewhere else.
Regards
Jaco
by gupta9665 » Tue Oct 29, 2024 11:02 pm
You need to get the current sheet, and then turn off the sheet format visibility.
Try
Option Explicit
Dim swModel As ModelDoc2
Dim currentsheet As Sheet
Dim boolstatus As Boolean
Set swModel = swApp.ActiveDoc
boolstatus = Part.SetupSheet5("MW Sheet", 12, 12, 1, 20, False, "C:\SWDVault\Engineering\Z00 - Solidworks\sheetformat\TAG_MW_Single_View.slddrt", 0.42, 0.297, "Default", False)
Set currentsheet = swModel.GetCurrentSheet
currentsheet.SheetFormatVisible = False
x 2312
x 1948
Re: How to unselect "Display sheet Format" in VBA
Jacomuller
x 36
x 5
#SPerman - I have tried it before and it use to work, but for some reason it is not working now. This is my code:
Option Explicit
Dim swDraw As SldWorks.DrawingDoc
Dim swSheet As Sheet
Dim SelMan As SldWorks.SelectionMgr
Dim retval As Boolean
Dim vSheetProps As Variant
Dim TemplateName As String
Dim instance As ISheet
    TemplateName = "C:\SWDVault\Engineering\Z00 - Solidworks\sheetformat\TAG_MW_Single_View.slddrt"
    Set swDraw = swApp.ActiveDoc
    'swApp.SendMsgToUser "Complete"
    retval = swDraw.NewSheet3("MW Sheet", swDwgPapersUserDefined, swDwgTemplateCustom, 1, 20, False, TemplateName , 0.08, 0.08, "MW View") ' TAG_MW_Single_View.slddrt
    swDraw.ActivateSheet ("MW Sheet")
   ' Get the drawing document
    ' Get the active document
'    swDraw.SheetFormatVisible = False
    instance.SheetFormatVisible = False
    .......more code
Jacomuller
x 36
x 5
In a similar case, how do I set "Display all configuration of the same part as one item" as "Part configuration Grouping" with VBA code?
Jacomuller
x 36
x 5
Hi @RonE
Do you have some wisdom about this issue? It should be very similar to the problem you solved earlier - I am just not skilled enough to connect the dots. grumph
Regards
Jaco
Answers: 26
x 445
x 469
Try
Option Explicit
Jacomuller
x 36
x 5
Thanks @gupta9665 . It is now working fine.
