Does SolidWorks offer note "styles"?
Mike Gera
x 98
x 40
Unread post by Mike Gera »
Say I want to define different font styles and select one before I create a new note on an .SLDDRW, similar to the "style" command in AutoCAD.
Is this possible in SolidWorks?
Thanks.
SW 2024 SP 5.0
Windows 11
x 2357
x 1973
Re: Does SolidWorks offer note "styles"?
I think style favorites will do what you want.
Mike Gera
x 98
x 40
That's what I was looking for thanks.
Is there a way to make a style available across multiple .slddrw files? I noticed that "Styles" is not in the File Locations list.
SW 2024 SP 5.0
Windows 11
x 2518
x 2132
Mike Gera wrote: Mon Nov 04, 2024 3:22 pm That's what I was looking for thanks.
You can save them externally and import them as annotations I believe, that is what we do.
Mike Gera
x 98
x 40
AlexLachance wrote: Mon Nov 04, 2024 3:59 pm You can save them externally and import them as annotations I believe, that is what we do.
Would I have to do that every time I open an .SLDDRW? Thanks.
SW 2024 SP 5.0
Windows 11
x 2518
x 2132
Mike Gera wrote: Tue Nov 05, 2024 9:17 am Would I have to do that every time I open an .SLDDRW? Thanks.
If it's been inserted once in it, it remains as a "favorite", if it's never been inserted, it needs to be inserted to fall in the favorite category. Maybe you could insert it into your template and it would be part of the favorites of the template? Not sure on that.
Bryan O
x 18
x 39
Unread post by Bryan O »
This might not be what your looking for but I used to have the common notes and blocks in my templates.
I now store many things in our design library: notes, blocks, common features (Library Feature Parts). I even store some starter assemblies in there, much like templates.
Notes you can set up to display in the font/style you want, once, and then drag and drop it in.
x 2518
x 2132
Bryan O wrote: Tue Nov 05, 2024 11:13 am This might not be what your looking for but I used to have the common notes and blocks in my templates.
Notes you can set up to display in the font/style you want, once, and then drag and drop it in.image.png
This is pretty much how we have it set up also. Drag what you need when you need it.
x 1817
x 2169
I've been using Note Styles (and Dimension Styles) for many years. If you will set them up and save as Drawing Template, then they will be available in any drawings using that template moving forward. I have different Styles saved for different templates, which works well for me.
