Hole Callout - C'Sink angle precision
RMcHugh
x 92
x 29
Unread post by RMcHugh »
I’m spending some time housekeeping and fixing some annoyances with our setup.
How do I set the default precision on drawings for Hole Wizard Countersunk Holes?
The model is set to 0 decimal places and the drawing template is set to 0 places.
The “Insert, Hole Callout” dimension always comes in at 3 places, forcing a manual adjustment.
I’ve done a bit of searching and haven’t found a setting for this.
Has anyone found a way to set the precision?
SWX 2022 SP5, PDM Standard, not upgrading for a bit due to hardware requirements.
Thanks,
Ray
x 2312
x 1948
Re: Hole Callout - C'Sink angle precision
I haven't found a way to control this.
DavidWS
x 26
x 12
Unread post by DavidWS »
In the model, at the bottom section of the hole wizard properties panel are the tolerance settings
On the drawing, the precision is controlled by the document/template settings:
RMcHugh
x 92
x 29
Thanks, @SPerman, that's what I've found.
Thank you, @DavidWS, but that had no effect on the drawing dimension.
x 893
This is broken as far back as SW2017.
BR10000387407 - Unable to control Hole callout angle precision using document settings. It follows the length dimension precision instead of angle precision
x 2312
x 1948
grumph
RMcHugh
x 92
x 29
Not the answer I was hoping for.
Thank you all. I appreciate your input.
tate876
Unread post by tate876 »
I ran into this same issue a while back! It looks like there isn't a direct setting to change the default precision for Hole Wizard callouts.
