New Server and Vault view recreation
Discuss SolidWorks PDM
x 743
x 367
We have to move the servers to new machines with new IP and host name and I would like to make a one click script to handle a smooth setting for all our workstations.
I have searched the KB and the closest Q&A I found on the topic says that it is not possible to batch destroy a vault view.
I am not so convinced, If I kill the epdm.exe task and console delete the vault view, then overwrite the registry I should be able to reroute to my new servers? Am I missing something? Yes, it would be not supported etc...
I have PDM and SW installed with an admin image so everybody has the same setup regarding PDM.
I am not interested in PDM client uninstall.
I have already made a CVS file to install a new vault view via batch.
Q&A Is it possible to completely uninstall the SOLIDWORKS® PDM client and remove the local view via a command line script?
Portfolio / Domain: SOLIDWORKS Desktop / GOVERNANCE
Product: SOLIDWORKS PDM Professional CAD Editor Network
Platform: On Premise
Question
Answer
There is no automatic method to remove a vault view. To manually perform the complete uninstall:
1. Right-click view and remove it.
2. Uninstall Enterprise from add/remove programs
3. Delete the SOLIDWORKS® PDM registry keys.
To perform the clean uninstall via command line script , use a *.bat file and perform the steps in the following order:
1. Uninstall Enterprise using MSIEXEC /x as described in knowledge base solution QA00000108838
2. Delete the two Enterprise registry keys:
HKEY_CURRENT_USER\Software\SolidWorks\Applications\PDMWorks Enterprise
HKEY_LOCAL_MACHINE\SOFTWARE\SolidWorks\Applications\PDMWorks Enterprise
3. Delete the (now orphaned) local view folder.
Keep in mind that this will completely remove SOLIDWORKS PDM, so any checked out files to that view will still show as checked out in the database. Please ensure that users check in all files before attempting this operation.
For additional help with completely removing SOLIDWORKS PDM, please contact either your Local SOLIDWORKS Reseller or SOLIDWORKS Technical Support.
Answers: 32
x 1263
x 2054
Re: New Server and Vault view recreation
If the vault name is the same, you can just update the server names in the client registry. Kill the PDM processes in a script then change the keys for "DbServer" and "ServerLoc" in these two locations:
Computer\HKEY_LOCAL_MACHINE\SOFTWARE\SolidWorks\Applications\PDMWorks Enterprise\Databases
Computer\HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\SolidWorks\Applications\PDMWorks Enterprise\Databases
You may also need to make adjustments in the "Current User" registry for the Admin tool if the users use it.
Computer\HKEY_CURRENT_USER\Software\SolidWorks\Applications\PDMWorks Enterprise\ConisioAdmin\Servers
Batch script to kill PDM processes:
taskkill /f /IM explorer.exe
taskkill /f /IM EDMSERVER.exe
taskkill /f /IM EDMSER~1.exe
taskkill /f /IM Search.exe
taskkill /f /IM AddInSrv.exe
taskkill /f /IM ViewServer.exe
start explorer.exe
exit
x 743
x 367
thank you for the batch, I was usually killing edmserver and explorer after checking if sldworks was in execution to avoid a registry overwrite when it closes.
I will lookup the othet exes to better understand what they do.
Do you think it is better to delete the whole vault folder and remake it?
If not recreated I think the ini file in the vault root needs to be updated with the new server info
x 278
x 463
mp3-250 wrote: Tue Dec 03, 2024 6:37 pm thank you for the batch, I was usually killing edmserver and explorer after checking if sldworks was in execution to avoid a registry overwrite when it closes.
One thing to keep an eye out for is that if you destroy a vault view and re-make it, then anything the user had checked out before the vault view was deleted won't be able to be checked back in after creating the new view. The vault view has a unique ID that is created when the view is made. So a new view would have a different ID and the server would see that as a different PC trying to check in the file.
As @jcapriotti said, the best method is to change the server registry keys to the new server info.
Answers: 32
x 1263
x 2054
Search.exe is the standalone search tool
AddInSrv.exe Is for add-ins that may be executing in the background.
ViewServer.exe I think is something to do with the built in viewer.
mp3-250 wrote: Tue Dec 03, 2024 6:37 pm Do you think it is better to delete the whole vault folder and remake it?
I would avoid recreating if possible. Even though the ini does contain the line:
AttachedFrom=ArchiveServer:3030
It should still work.......you can test a client if you have your new servers up. If not, a batch script to edit the file or replace it with another copy should be easy.
