In a drawing, with a view selected:
Insert > Annotations > Centerline...
Auto Insert "Select View" checked
Centerlines are being inserted for holes, which I want, but they are also being inserted for fillets/radii, which I do not want.
How do I change this?
Thanks.
how to stop "view" insert of fillet/radius centerines
- x 2486
- x 2101
Re: how to stop "view" insert of fillet/radius centerines
Do you have this checked? "For all fillets"Mike Gera wrote: ↑Thu Dec 19, 2024 3:11 pm In a drawing, with a view selected:
Thanks.
Thanks, Alex.
I do not have all the options that you do. I only see this:
SW 2024 SP 5.0
Windows 11
Windows 11
In your drawing template, if you look at "Options -> Document Properties -> Detailing", there is a section for "Auto insert on view creation" that will put centerlines/centermarks based on your selections.
- x 2486
- x 2101
- x 824
- x 1011
In the almost 20 years that I have been using Solidworks, I think I used that function twice.
Both times I tried to get it to be what I wanted without adding fluff to views that I didn't want.
Then I shelved it and have just put all my center marks in manually.
I have all of that stuff unchecked.AlexLachance wrote: ↑Thu Dec 19, 2024 3:43 pm Yeah, my apologies, in french it is not the same command. I get the same result as you with the same command.
This is most likely what you need to toggle
Edit: What AlexB said!
SW 2024 SP 5.0
Windows 11
Windows 11
