SolidProfessor Skills Analyzer Contest Nonsense
x 893
So, our reseller is pushing a SolidProfessor Skills Analyzer contest. There are 3 levels (basic, advanced and expert). For giggles I took the Basic exam and was shocked to see that I supposedly missed question 1 in the sketching section:
My answer is 100% correct. You cannot know that X and Y are aligned. Exhibit A:
and the proof:
I'll be skipping the other two challenges when they are dropped.
x 1660
x 1498
Re: SolidProfessor Skills Analyzer Contest Nonsense
Show all sketch constrains.
x 2467
x 2096
JSculley wrote: Thu Jan 09, 2025 9:51 am So, our reseller is pushing a SolidProfessor Skills Analyzer contest. There are 3 levels (basic, advanced and expert). For giggles I took the Basic exam and was shocked to see that I supposedly missed question 1 in the sketching section:
and the proof:
I don't know how you did it to get an angle in your image, but the construction line linking the two is what should tell you that they are aligned.
Answers: 26
x 821
x 1008
AlexLachance wrote: Thu Jan 09, 2025 10:43 am I don't know how you did it to get an angle in your image, but the construction line linking the two is what should tell you that they are aligned.
The one from the contest is missing the constraints that you are showing in yours.
If the constraints are showing, or this were on a technical drawing with ASME requirements, then yes, I would say that you can tell that they are aligned.
But on a sketch where you can't see the constraints and can only look at it. @JSculley is absolutely correct.
x 2467
x 2096
DanPihlaja wrote: Thu Jan 09, 2025 10:56 am The one from the contest is missing the constraints that you are showing in yours.
The constraints are not shown in the image because it's an exam, it's made to test your knowledge. When you draw a line with your pencil on a sheet of paper using a ruler, do you see a mate appear? I was thought in school that a line that looks straight is straight unless identified otherwise.
dave.laban
Answers: 5
x 48
x 409
Unread post by dave.laban »
Assuming it was a multiple choice question I'd be curious to see the offered answers.
I'd agree you can't know but it would be an extremely safe assumption that in the absence of any other dimensions or geometry to the contrary, the construction line is coincident and parallel, and the dimensions are based off of parallel lines and not sketch points.
x 2577
x 1427
AlexLachance wrote: Thu Jan 09, 2025 11:08 am The constraints are not shown in the image because it's an exam, it's made to test your knowledge. When you draw a line with your pencil on a sheet of paper using a ruler, do you see a mate appear? I was thought in school that a line that looks straight is straight unless identified otherwise.
Agree with this line of thought on drawings and hand sketches, but no farther. I highly doubt that I could ever draw two lines parallel to with in 0.00025977deg on paper. In CAD sketching nothing should be assumed. The sketch relations, as others have stated, should be turned on to show design intent. I can only imagine the amount of scrapped material cut on the laser from a dxf generated from a model controlled by a sketch that looked correct. In this case, would the part work, probably. Until it's revised to have 15mm changed to 16mm to improve weld fit up or whatever. The other leg will not move predictably and likely not noticed when a few hundred parts are cut then there's another revision to lengthen the other leg. It's just silly. It's a 3D sketch, not an ANSI drawing.
x 25
x 561
What kind of hidden constraint can make those lines fully defined but not collinear? I suppose "fixed"?
x 2467
x 2096
Let's ignore the mates then. If the sketch is entirely black and the left line is parralel to the right line, the dimensions between the top line and the middle line indicates parrallelism.
The dimension between the top line and bottom line indicate parrallelism.
The lack of dimension anywhere else indicates that the bottom lines are colinear, since the sketch is black and fully mated.
x 893
dave.laban wrote: Thu Jan 09, 2025 11:37 am Assuming it was a multiple choice question I'd be curious to see the offered answers.
Yes, it's multiple choice. Here are the 4 answers:
Visual inspection? Nope. Unless your eye is calibrated to 0.0002 degrees
Construction line connecting the two lines? If this were a SOLIDWORKS drawing, maybe I'd accept this answer. This however is a SOLIDWORKS sketch, as evidenced by the visible Sketch origin. Absent visible sketch relations, you cannot assume anything about the relationship between the three lines.
The "fact" that the two lines are horizontal? How is that a fact when there is nothing (e.g. sketch relations) to indicate it?
x 893
josh wrote: Thu Jan 09, 2025 11:45 am What kind of hidden constraint can make those lines fully defined but not collinear? I suppose "fixed"?
Yep. One 'Fixed' constraint and chaos ensues:
x 2467
x 2096
To add to what I said, construction lines are often used as a visual aid to point to something. The fact that it was there indicated they were colinear.
MattW
x 5
x 36
Unread post by MattW »
Given standard SW colors of black = fully constrained and blue = not fully constrained, I am not seeing how you could get Y not be colinear with X and have Y black, absent a fixed relation. The quiz sketch even shows sketch relations, which I don't think are needed. I don't think you even need the construction line. I've been trying to get an all black sketch without X and Y in alignment- no luck. Maybe someone can post up how to do it.
Answers: 32
x 1256
x 2045
As mentioned already, if this were an ASME drawing, the centerline would indicate or imply that they are colinear. But for SolidWorks, you need the relations shown to know.
Not sure which skill they are testing, the ability to interpret a drawing's intent, or ability to recognize what the SolidWorks sketch solver is doing. I assume the latter since SolidProfessor is a CAD training tool and not a drafting standards training tool. So you're answer is correct @JSculley.
Answers: 32
x 1256
x 2045
MattW wrote: Thu Jan 09, 2025 1:09 pm Maybe someone can post up how to do it.
Ok...I "fixed" it. The point being that you need the relations show to truly know in SolidWorks.
x 2577
x 1427
We've been using Solid Professor for new hires. Based on this I feel like I have to go through them myself, if this is representative of the rest of it I think we'll be looking elsewhere.
MattW
x 5
x 36
jcapriotti wrote: Thu Jan 09, 2025 1:21 pm image.png
Can you post the file?
MattW
x 5
x 36
[/quote]
OK, I clued in. I did say absent a fixed relation. The quiz question shows the relations, shows X, Y, and the construction line all horizontal, X coincident with the origin. I don't know how to make X and Y not colinear under those constraints.
x 25
x 561
There are times to be absolutely precise and times to be pedantic. For purposes of posturing and pedantry, you are correct. For the purposes of a "basic" assessment of SW knowledge and skill, the "construction line" answer is best. Granted, it does assume that the sketch was not made by either an utter incompetent or someone with malicious intent. If I were to open that all-black sketch, I would also assume that the lines are collinear until something broke, then I would berate whoever used a fixed constraint. For all that matter, how do you know that the dimensions are attached to the sketch entities, or that the construction line is actually connected to the others? The lines could all be offset by some infinitesimal amount and fixed.
This is like complaining that a high-school physics f=ma problem is wrong because it is not accounting for relativity.
x 893
josh wrote: Thu Jan 09, 2025 1:52 pm There are times to be absolutely precise and times to be pedantic. For purposes of posturing and pedantry, you are correct. For the purposes of a "basic" assessment of SW knowledge and skill, the "construction line" answer is best.
Not when one of the other offered multiple choice answers is more correct. If I had to choose between the first three, then as I've said, the construction line answer is best, but they offered up that fourth choice, which is more correct than the other 3.
Only if the physics problem was multiple choice and included an answer that accounted for relativity that was marked wrong.
x 25
x 561
JSculley wrote: Thu Jan 09, 2025 2:30 pm
If you're going to be pedantic, I'll pedant right back at you. It would be like answering "none of the above" when an answer is present that is correct according to Newtonian mechanics. The intent of the question is absolutely clear. Complaining about it because you can intentionally construct a counterexample that's beyond the scope is posturing and pedantic. The test is clearly not intended for someone of your skill level, and is not intended to evaluate you. That doesn't mean it's a bad test, or that it shouldn't be used to evaluate the target level of SW user. Could it be improved or better worded? Sure. Again, not saying you're incorrect. Just being pedantic.
Answers: 32
x 1256
x 2045
josh wrote: Thu Jan 09, 2025 2:59 pm That doesn't mean it's a bad test, or that it shouldn't be used to evaluate the target level of SW user. Could it be improved or better worded?
I don't think anyone is suggesting that the question was meant to intentionally be ambiguous, unless we want to go down the conspiracy theory rabbit hole and say that Solid Professor wants you to do poorly so you will buy their product :twisted:.
I could see myself second guessing what the correct answer would be due to "too much" experience :lol:. In my youth I'd likely not questioned it. I think an update to the picture to show sketch relations would address the issue.
x 893
jcapriotti wrote: Thu Jan 09, 2025 3:48 pm I think an update to the picture to show sketch relations would address the issue.
Indeed. Especially since that is what is shown by default in SW which is what a novice user would see.
x 1660
x 1498
Just did the second part:
dave.laban
Answers: 5
x 48
x 409
x 25
x 561
LOL what kind of question is this? I had no idea what they were trying to ask, and the listed answer options didn't help...
dave.laban
Answers: 5
x 48
x 409
84% in 06:53 on the second part. I was tripping over the wording of the question more than anything else. And dropped marks on things I don't use so...meh.
Answers: 26
x 445
x 471
Here is mine, just missed one question as I misread it.
dave.laban
Answers: 5
x 48
x 409
dave.laban wrote: Mon Jan 13, 2025 10:17 am Relevant link for giggles. https://r1132100503382-eu1-3dswym.3dexp ... f6sEpemhWA
Hah. Nice to see resellers aren't exempt from advertising *checks notes* SolidWorks related products on 3DSwym.
x 25
x 561
Yeah, I think they might have gotten away with it if not for the part where the "correct" answers are not shown but rather you're referred to their training course.
CarrieIves
x 402
x 153
Unread post by CarrieIves »
bnemec wrote: Thu Jan 09, 2025 1:36 pm We've been using Solid Professor for new hires. Based on this I feel like I have to go through them myself, if this is representative of the rest of it I think we'll be looking elsewhere.
I have gone through a lot of their material. Questions that are not as clear as I think they should be is one thing I encountered. I didn't see anything that I thought would train in bad habits. We had it included in our subscription fee and if that was the only thing included in the increased subscription fee, I would have recommended that we go with the lower level subscription fee. I think it is a reasonable something to use for bringing people up to speed, but I would make sure to discuss all the company best practices and the whys of the best practices.
