How to control the display of Annotations in the model
mihkov
x 21
x 25
Unread post by mihkov »
When I create and work with the model, I have the Instant2D mode enabled, and if I select a sketch or feature in the design tree, then all the dimensions of this sketch or feature become visible in the graphics window. ! Temporarily ! until I click in an empty field or select an operation. After that, they disappear.
If I decide to add an Annotation to the model, for example: Cosmetic Thread, then all "Annotations" from all sketches and operations become visible, and their display is not reset.
The only way to turn off their display is to:
press the button: View Top Level Annotations.
How can I prevent this effect from appearing?
Stefan Sterk
x 62
x 84
Re: How to control the display of Annotations in the model
Unread post by Stefan Sterk »
@mihkov
RMB on the Annotations folder in the feature design tree and then disable 'Show Feature Dimensions'
