K-Factor in practice (sheet metal behavior)
Posted: Sun Jan 19, 2025 6:00 am
by kacper.suchomski
What is K-Factor?
What does it affect?
K-Factor is the coefficient of the position of the neutral surface (of constant length) of the material during linear deformation machining.
It is used for bending and rolling.
In many cases, the analysis and correct application of this parameter can be omitted - in the case of thin sheets, the error incurred in the process will usually fit within the product manufacturing tolerance.
However, ignoring this issue can cause a lot of trouble when producing larger parts.
Incorrect selection of K-Factor in the process of modeling large-sized parts from thick material can cause a difference of several or even several dozen centimeters between the expected (nominal) size and the size obtained in the production process.
This inconspicuous parameter can expose the company to huge losses of time, material and money.
If you want to know how the K-Factor definition affects the material's behavior in practice - watch the latest presentation 👇
Subscribe to never miss another CAD lesson
Re: K-Factor in practice (sheet metal behavior)
Posted: Tue Jan 21, 2025 12:55 pm
@kacper.suchomski Since many of the users here only speak English, it may be useful to record your videos with your system settings in English so the commands and tree in Inventor are in English. Most people here don't speak Polish. I think you'll get more views.
