Does anyone have a font for cutting words into sheet metal that they would be willing to share? The centers of the letters need to be connected to the outside so they don't fall out when cut, which is why I can't use a standard font. I did a quick search online but didn't come up with anything that had the centers of the letters connected to the outside.
Any help is much appreciated!
Font for Laser Cutting?
- Jaylin Hochstetler
- x 375
- x 353
Re: Font for Laser Cutting?
If you search for "stencil font" there are many to pick from.
See if this works for youJaylin Hochstetler wrote: ↑Mon Apr 19, 2021 5:01 pm Does anyone have a font for cutting words into sheet metal that they would be willing to share? The centers of the letters need to be connected to the outside so they don't fall out when cut, which is why I can't use a standard font. I did a quick search online but didn't come up with anything that had the centers of the letters connected to the outside.
- DXF & DWG.zip
- (31.7 KiB) Downloaded 765 times
- STENCILS.zip
- (631.74 KiB) Downloaded 1075 times
- x 375
- x 353
Thanks for your help guys! I found one online that I attached.
- allerta.zip
- (2.04 MiB) Downloaded 1251 times
