My First Question Here...woot! How to mate tapers?
Posted: Thu May 06, 2021 11:54 am
by jmongi
So excited to make my first SW question on this forum!
So, we're redesigning a power takeoff assembly and the main shaft has a tapered end that mates in a tapered shaft carrier/hub. How would I go about mating that together in SW? It's not super critical, but the final fixed position of the shaft depends on those two mating surfaces and that sets the distance of the bearing surface on the shaft. I would like to see that everything has enough clearance space using the actual taper "interference".
Sorry if that's a bit long-winded. Using SW 2019 SP5.
Re: My First Question Here...woot! How to mate tapers?
Posted: Thu May 06, 2021 12:34 pm
by Uncle_Hairball
Post an assembly?
Posted: Thu May 06, 2021 12:35 pm
by matt
Use centerline or axes or temp axes
Posted: Thu May 06, 2021 12:38 pm
by jmongi
Axes will align the tapers, but how do i set the depth? I haven't actually had a chance to try anything yet. Got snagged for a hot issue that will be done in an hour.
Posted: Thu May 06, 2021 12:43 pm
by KevinC
jmongi wrote: ↑Thu May 06, 2021 12:38 pm
Is it a male taper into a conic female?
[After axes alignment]
You can add planes to each part and mate them coincident or at a distance from each other.
To mate male/female, you can select the circular female edge and mate coincident to the male's face.
Some screen shots would be helpful.
Posted: Thu May 06, 2021 12:51 pm
by MJuric
jmongi wrote: ↑Thu May 06, 2021 11:54 am
If the two tapers are the same you should be able to just do a coincident mate and done all but rotation.
If the tapers are different then the best way is axis and planes or axis and intersecting circle.
Posted: Thu May 06, 2021 12:59 pm
by JSculley
If the taper angles are identical, you can just use a single coincident mate between the circular edge at either end of the taper of one part and the conical face of the other part. SOLIDWORKS will work out where the two entities meet, even if it is outside the part boundaries:
Posted: Thu May 06, 2021 1:01 pm
by jmongi
Thanks to all who responded. They SHOULD be the same taper. My past issues my have been from tapers that were actually slightly different or some random SW issue with face selection order. Those options look like they should work. I'll be back on this in a minute.
Posted: Thu May 06, 2021 1:04 pm
by mattpeneguy
This is a CAD forum...I think you're in the wrong place...
- image.png (122.63 KiB) Viewed 1356 times
Posted: Thu May 06, 2021 1:25 pm
by jmongi
On the contrary, I think some need a CAD program to accomplish both kinds of mating....
Posted: Thu May 06, 2021 1:49 pm
by Roasted By John
mattpeneguy wrote: ↑Thu May 06, 2021 1:04 pm
According to that Picture, I decided that I'd still would like my permanent secretary, don't think I want a permanent taper
