RenameVirtualComponents.swp
Posted: Fri Mar 12, 2021 6:35 pm
edit_20210505: added macro attachment again. Maybe it was removed during the attack.
I just searched for removing copy of from Virtual Components and in just a couple of minutes I had found the post, downloaded the graciously shared macro and tested it. I thought to my self, in a month that will not be a possibility any longer. All of those shared macros, gone. So this one is not mine but it just helped me out.
posted by Koos Kubus
Option Explicit
Sub main()
    Dim swModel As ModelDoc2
    Dim swRootComp As SldWorks.Component2
    Set swModel = swApp.ActiveDoc
    'check if an assembly is open
    If swModel Is Nothing Then Exit Sub
    If Not swModel.GetType = swDocASSEMBLY Then Exit Sub
    'get root component for this assembly (configuration)
    Set swRootComp = swModel.ConfigurationManager.ActiveConfiguration.GetRootComponent3(True)
    TraverseAssembly swRootComp
' Traverse an assembly, to find all child-components
Sub TraverseAssembly(swComp As Component2)
    Dim swChildComp As SldWorks.Component2
    Dim vChild As Variant
    Dim ComponentsAtSameLevel As Collection
    Set ComponentsAtSameLevel = New Collection
    'try to loop through children of this component
    For Each vChild In swComp.GetChildren
            Set swChildComp = vChild
            'only change virtual components
            If swChildComp.IsVirtual Then
                'use this procedure as recursive procedure, to go one level deeper
                TraverseAssembly swChildComp
                ComponentsAtSameLevel.Add swChildComp
            End If
    Next vChild
    RenameComponentsCollection ComponentsAtSameLevel
'Rename all components in a collection
Sub RenameComponentsCollection(Components As Collection)
    Const Find1 As String = "Copy of "
    Const Find2 As String = ") of "
    Dim swComponent As Component2
    Dim NewName As String
    For Each swComponent In Components
        NewName = GetCompName(swComponent)
        RemoveLeftOfString NewName, Find1
        RemoveLeftOfString NewName, Find2
        RenameComponent swComponent, NewName
    Next swComponent
' Remove SubString (and all characters to the left of it) from the MainString
Sub RemoveLeftOfString(ByRef MainString As String, SubString As String)
    If InStrRev(MainString, SubString) <> 0 Then
        MainString = Right(MainString, Len(MainString) - InStrRev(MainString, SubString) - Len(SubString) + 1)
    End If
' Rename a Component and add an iterator if the new Component-name is not available
Sub RenameComponent(swComponent As Component2, NewName As String, Optional Iteration As Long)
    Dim NewNameWithIterator As String
    NewNameWithIterator = NewName
    If Iteration > 0 Then NewNameWithIterator = NewName & " " & Iteration
    swComponent.Select4 False, Nothing, False
    swComponent.Name2 = NewNameWithIterator
    If GetCompName(swComponent) <> NewNameWithIterator And Iteration < 10 Then
        RenameComponent swComponent, NewName, Iteration + 1
    End If
' Get the short name of the Component
Function GetCompName(swComp As Component2) As String
    Dim compname As String
    compname = swComp.Name2
    compname = Right(compname, Len(compname) - InStrRev(compname, "/"))
    compname = Left(compname, InStr(compname, "^") - 1)
    GetCompName = compname
End Function
Re: RenameVirtualComponents.swp
Posted: Fri Mar 12, 2021 6:39 pm
Nice, I need this one, didn't realize it was on the SolidWorks forum. We deal with a lot of vendor assemblies that are in SolidWorks but we only want the one assembly file in PDM.
