Get write access
Posted: Fri May 07, 2021 8:44 am
by Peter De Vlieger
Did I miss a memo?
There used to be the possibility to get 'write access' when working on a PRT or ASM that someone else had open by just doing a RMB and selecting it out of the pop up.
Am I losing it?
Did I imagine it?
Should I see to up my meds?
Re: Get write access
Posted: Fri May 07, 2021 8:55 am
Peter De Vlieger wrote: Fri May 07, 2021 8:44 am Did I miss a memo?
Am I losing it?
Did I imagine it?
No you're correct, there are instances of selections that makes it that do not show up, but it should generally show.
Have you looked if it was hidden unintentionally or by a SolidWorks bug?
Posted: Fri May 07, 2021 9:08 am
by Peter De Vlieger
Cheers Alex.
Of course now that I posted about it, it shows up
Posted: Fri May 07, 2021 9:14 am
Peter De Vlieger wrote: Fri May 07, 2021 9:08 am Cheers Alex.
Glad I could be of help :lol:
Posted: Sat May 08, 2021 4:33 am
by Rob
Hi @Peter De Vlieger
I believe this is where you turn it on/off
System Options > Collaboration > Enable multi-user environment > Add shortcut menu items...
Posted: Mon May 10, 2021 4:15 am
by Peter De Vlieger
Ron,
That is right.
However I never change that setting so there for, silly ol' me, I expect it to work.
