Angular Limit Mate w/ Axes?
Posted: Sun May 09, 2021 1:00 pm
by Ballfreak10
Hi all,
In the assembly of the attached folder (titled "Mouse"), I'm looking to add an angular limit mate between the Top Plane of the assembly and both of the axes labeled as "Axis_Angle Mate".
However, when I select both entities as mate entities, angular options are greyed out (see attached screenshot!).
Is this because axes aren't valid mate entities for angular mates, or otherwise?
All help is appreciated :)!
Thanks in advance,
Re: Angular Limit Mate w/ Axes?
Posted: Sun May 09, 2021 6:58 pm
by josh
You can't create an angle mate between a linear entity (axis, edge, line, etc) and a planar entity.
You can create angle mates between two linear entities, or between two planar entities.
