Need macro to export to 2 diffrent locations
Library for macros
pitbullxp
x 4
x 4
Unread post by pitbullxp »
Hi all,
currently we use a macro to export PDF/DXF and STEP files to the folder of the part/drawing. the macro takes the filename and add the revision to it and it works great(unless file has the same name and is checked in, then whole solidworks will stop). We can simply locate the files and copy them to the right place so the purchasing team can start their job. But there are time's that we forget something, they will search for the file in the project folder, they cant find it, then we get a coll, drop everything, look up the file and place it in the right folder. Give them a call to say we placed the file.
To fix that i want to implement a dump folder. So when we use the macro, it will place a file in the folder of the part/drawing, but it will also place te same file in a folder tekening dump (drawing dump)
I've spent to much time searching for a macro with the same idea, but i only get results like, multiple drawings in 1 pdf, multiple parts at the same time ect.
I don't have any experience in coding, but i want to learn and understand them, so if you can help me with the code en explain it a bit, it would be very appreciated
x 600
Re: Need macro to export to 2 diffrent locations
Without looking at the actual code i cant really explain it well...
But ideally what you need is just a separate line that call out a 2nd save function, somethings like the below
You might need to pre-process your file
swModel.SaveAs SaveFileName
swModel.SaveAs SaveFileNameDump
SaveFileNameDump is point to your dump folder
Edit:
See example below, it will save the file as step into two folder, colored in red
Option Explicit
Dim SavePath As String
Dim SavePathDump As String
Dim SaveFileName As String
'Example macro
'Macro will save as step into 2 different folder,
Set swModel = swApp.ActiveDoc 'Get active document
If swModel Is Nothing Then 'Display message and terminate if nothing is open
MsgBox "Please open a file first.", vbOKOnly
End
'Folder path, path need to end with \
SavePathDump = "C:\CADForum\6303\DumpFolder" & "\"
SavePath = "C:\CADForum\6303\PartFolder" & "\"
SaveFileName = swModel.GetPathName 'Get path name of active document
SaveFileName = Mid(SaveFileName, InStrRev(SaveFileName, "\") + 1) 'Remove address, keep only file name (with extension)
SaveFileName = Left(SaveFileName, InStrRev(SaveFileName, ".") - 1) 'Remove file extension
swModel.SaveAs SavePath & SaveFileName & ".step"
swModel.SaveAs SavePathDump & SaveFileName & ".step"
Set swModel = Nothing
pitbullxp
x 4
x 4
Hi thanks for the help.
The macro i use to save .STEP is by Deepak and i had to make some changes to some values so it would work for me.
With the changes i made with insperation from your code it worked. It can now save on the original folder and the dump folder.
I also changed the .STEP to a combination for .DXF and .PDF but it will add "sheet 1" in the middle
    Set Part = swApp.ActiveDoc
    longstatus = Part.SaveAs3(FilePath & swModel.GetTitle & "-" & Rev & ".DXF", 0, 0)
    longstatus = Part.SaveAs3(FilePathDump & swModel.GetTitle & "-" & Rev & ".DXF", 0, 0)
    longstatus = Part.SaveAs3(FilePath & swModel.GetTitle & "-" & Rev & ".PDF", 0, 0)
    longstatus = Part.SaveAs3(FilePathDump & swModel.GetTitle & "-" & Rev & ".PDF", 0, 0)
Here the code i changed, if you see something that's unnecessary or can be better i like to know.
' DXF Saving part Written by: Deepak Gupta (http://gupta9665.wordpress.com/)
Option Explicit
    Dim swApp               As Object
    Dim swCustPrpMgr        As SldWorks.CustomPropertyManager
    Dim nResponse           As Integer
    Dim Rev                 As String
    Dim Thickness           As String
    Dim FilePath            As String
    Dim FilePathDump        As String
    Dim Part                As Object
    Dim SelMgr              As Object
    Dim boolstatus          As Boolean
    Dim Feature As Object
    Dim Filename, Name As String
    Dim Pos, Length As Long
Sub DesignExport()
'Get Document Path
    FilePath = Left(swModel.GetPathName, InStrRev(swModel.GetPathName, "\"))
    FilePathDump = "\\SANINAS\Productie\2. projecten\#Tekening DUMP" & "\"
'Get Custom Property
   Set swCustPrpMgr = swModel.Extension.CustomPropertyManager("")
   swCustPrpMgr.Get3 "Revision", False, "##", Rev
'Save As STEP
    longstatus = Part.SaveAs3(FilePath & swModel.GetTitle & "-" & Rev & ".STEP", 0, 0)
    longstatus = Part.SaveAs3(FilePathDump & swModel.GetTitle & "-" & Rev & ".STEP", 0, 0)
What can i change so the drawing export part will work?
x 600
pitbullxp wrote: Wed May 12, 2021 9:07 am What can i change so the drawing export part will work?
Sorry i am abit confused... What is not working?
I took a quick glance at the macro and everything seem fine
PS:
Some suggestion... personally i will try to avoid using GetTitle as if i remember correctly the value return by GetTitle could varies depend on user Window explorer setting. My personal preference is to use GetPathName and then strip the path and extension (if any) using Mid and Left
pitbullxp
x 4
x 4
When I get back to work I will look at the code to change it to getpathname.
When I change the export ripe to PDF or dxf it will add the sheet name. In the middle.
So filename-sheetname-revision.pdf
x 600
pitbullxp wrote: Thu May 13, 2021 6:48 am When I get back to work I will look at the code to change it to getpathname.
Ah yes, thats the issue with GetTitle
GetTitle will get whatever that is display on your SOLIDWORKS window, for drawing it will be XXXXX-SheetX, thats why you get the sheet name when you export as pdf/dxf
Change it to GetPathName and it should work properly :D.
pitbullxp
x 4
x 4
That was the solution, it works. Thank you
Stefan Sterk
x 60
x 83
Unread post by Stefan Sterk »
Why would you perform the export twice and not just copy paste the file that you have exported with the FileCopy function?
FirstPathName = FilePath & SaveFileName  & "-" & Rev & ".STEP"
SecondPathName = FilePathDump & SaveFileName & "-" & Rev & ".STEP"
' Export STEP to first path
longstatus = Part.SaveAs3(FirstPathName , 0, 0)
' Copy paste exported STEP to second path
FileCopy FirstPathName, SecondPathName
Or use
Dim fso As Object
Set fso = CreateObject("Scripting.FileSystemObject")
Call fso.CopyFile FirstPathName, SecondPathName
Jean-Paul Commeene
Unread post by Jean-Paul Commeene »
Hi all,
As i am new here on the forum i don't know if my question will be on the correct place.
For quit some time i'm looking for a macro/solution to save my part and drawing to different file types in the same folder. the SLDPRT file should be saved as a flatt patern dxf file and a step file. the slddrw should be saved as a PDF.
writinig a macro can be the solution but i do not have any experience in this.
does anybody have this on the shelf?
Many thanks!
JP
Answers: 26
x 445
x 469
JP, how you want the macro to work? I mean do you want it to save STEP when part model is active and save PDF when drawing is active. OR do you want it to save PDF and STEP both when drawing is active.
J_the_King
Unread post by J_the_King »
Hi @gupta9665,
I also used your code as reference.
But I have an issue when I have multiple documents open. Creating a PDF does work, but when creating a STEP the previous used part will be used instead of the part referenced to the drawing.
Can you help me with that?
I already appreciate your code very much.
Kind regards,
Jordy
