Syntax Highlighting for Programming Code
Make suggestion to the moderators and admins of this site.
Answers: 54
x 7
x 811
The Jive forum included a syntax highlighting tool for posting code. Very helpful. There is a phpBB 3.3 plugin that does this sort of thing:
https://www.phpbb.com/community/viewtopic.php?t=2557806
It's still in BETA but the install/uninstall looks straightforward. Any chance this can be installed so we can take it for a test drive?
x 1158
x 2294
Re: Syntax Highlighting for Programming Code
Notice a little late, but for reference, this has been activated. I don't know how to use it, but it should let you fotmst code in the post editor box.
Answers: 54
x 7
x 811
To use it, you simply wrap the code in 'code' tags and put the name of the programming language as an attribute. So this:
[ code=java]
public class HelloWorld {
public static void main(String[ ]args) {
System.out.println("Hello World!");
[ /code]
becomes this:
x 2487
x 1888
JSculley wrote: Mon Jun 28, 2021 7:45 am To use it, you simply wrap the code in 'code' tags and put the name of the programming language as an attribute. So this:
[ code=java]
[ /code]
becomes this:
Pfft...Who still uses Java?...Regardless, this functionality doesn't work for me...:
[ code=c64]
LOAD"SOLIDWORKS",8,1
[ /code]
Answers: 54
x 7
x 811
mattpeneguy wrote: Mon Jun 28, 2021 9:10 am Pfft...Who still uses Java?...Regardless, this functionality doesn't work for me...:
[ code=c64]
[ /code]
Because c64 is a platform, not a language. Try 'basic': 8-)
