How to link a dimension to another dimension in another part in the same assembly
Tera
x 483
x 91
Unread post by Tera »
I'm sure I was able to do the following procedure in previous versions, but it seems this time it's failing. Maybe some settings somewhere?
In the following image I want to link a dimension in Sketch23 to a dimension in Sketch27. (different component, same assembly)
While in edit mode of Sketch23, I double click 8.7, type an = sign in modify box, double click Sketch27 to show the dimensions, but I can not pick 5.0 to make a linked dimension.
  • SolidWorks 2021 SP3
  • I don't want to use global variables in this specific case.
Any kind of help is much appreciated.
by Tera » Thu May 13, 2021 9:14 pm
I hate when Solidworks acts stupid. I had to close and launch SW again. After that, I was able to do the task.
@Maha Nadarasa Million thanks for your time and trying to help.
Maha Nadarasa
x 51
x 48
Re: How to link a dimension to another dimension in another part in the same assembly
Try top down assembly modeling.
Tera
x 483
x 91
Maha Nadarasa wrote: Thu May 13, 2021 8:11 pm Try top down assembly modeling.
It is.
Maha Nadarasa
x 51
x 48
File?
Tera
x 483
x 91
Sorry. But I'm not allowed to share it. Even for posting the image I had to ask for permission first.
Is the method I'm talking about works for you in 2021 sp3 version?
Is there any setting (concerning external references) for this?
Maha Nadarasa
x 51
x 48
Sorry without file my idea is limited. Some one may give better idea.
Tera
x 483
x 91
Maha Nadarasa
x 51
x 48
Issues are good because those are challenges it will take your knowledge to next upper level.
Ömür Tokman
x 994
x 347
Unread post by Ömür Tokman »
Hi Tera,
Is this what you are talking about?
Roasted By John
x 268
x 583
Maha Nadarasa wrote: Thu May 13, 2021 9:24 pm Issues are good because those are challenges it will take your knowledge to next upper level.
Very well said Maha :)
www.martinsroastapig.com
Pig Roast Your Way
Maha Nadarasa
x 51
x 48
@Roasted By John
Thanks for recognizing it.
