![hmm maybe not ()](./images/smilies/shuffle.gif)
Anyhow, here's one to get it started. Please note that I am using a Solidworks certified graphics card...
![grumph grumph](./images/smilies/e21589.gif)
It is not a bug, it is personal. You are not paranoid, SWX really IS out to get you!mike miller wrote: ↑Tue Jun 08, 2021 9:51 am What on earth Solidworks?
See all those bend lines? Ctrl+Shift+Q does nothing. They are NOT showing in the part level, only in the assembly. Even weirder, the only way to fix it is to open each part file and close it; you don't even have to save it!
Oh that's a can of worms. Manually hiding all sketches and planes? Yeaaaaahh.........no thanks. That makes the Hide/Show toggles useless. How will you find something if you ever need it?Merovingien wrote: ↑Fri Jun 25, 2021 11:16 am you are working with an "opposite workflow", as the basic use of SW...
one basic is : in design tree, every sketch-construction are hidden.
except for some rare sketch you will need to use in upper ASM.
never work with the display-filter : hide all (you are working in a bad way with SW, like an opposite-thinking)
so disable "hide all"
hide all sketch in you tree
hide all "others things" in design tree, you see in 3D graphics, but you don' want to see.
(axis, plane, point...)
also, level of detail : set it at 4 graduations from the right side.
anti-aliasing can slower some 3D graphic viewer (i prefer set it off)
RealView also slower a little the gpu a little (i prefer set it off)
it also exists others settings elsewhere... to speed up 3D graphic SW.
Now that is weird! Was that photo-shopped?
THat looks like the cosmetic threads after you moved them in your model before opening up the drawing. We see that all the time & have reported it but like all other bugs they don't pay any attention to them.
Wild... could be a display state toggle?Jaylin Hochstetler wrote: ↑Fri Aug 20, 2021 6:31 am The other day I had a strange one, too. I had drawing view of an assembly but as soon as I would click "save as" to save it as a PDF the one part in the assembly would turn to "Hidden Lines Removed". I saved and closed the assembly and then it worked fine.
Seen it and I've rebooted just because it is too weird.
Meh... I've never used Perspective mode - or so far I haven't used it. I wonder whether the issue might relate to GPU firmware... but what are the odds... I'm not sure am I the only one in my company using this computer setup. I have been thinking if I should reinstall all GPU software and firmware. Well... idk.
It would've be funny if one of those @ symbols had ended up in front of the $$.mike miller wrote: ↑Thu Nov 18, 2021 4:31 pm This is a weird one. I noticed when adding a part to an assembly SWX allows you to pick a Solid Edge document. Of course, I had to try this........ Well, it appeared to do nothing until I noticed a feature below the rollback bar. LOL!!
This graphics glitch is affected by the options 'Display dimensions flat to screen'.
