How to Paste a property value inside of an excel cell
Programming and macros
ResidentAtLarge
x 30
Unread post by ResidentAtLarge »
I am pretty new to the API with very little programming experience.
I've looked at the solidworks API Help and I am not sure on which command to use.
My code that I currently have copies from a specific cell and puts the value into the custom property that I've defined.
What I would like to do is to copy the value of a custom property and paste it in a specific cell of the workbook first. then copy the value of a different cell back to a different solidworks property. I have the last part, but I'm looking to do the first part.
Any help would be fantasic! Thank you!
Here is the code that I have.
'Dim swApp As Object
'Dim Part As Object
'Dim boolstatus As Boolean
'Dim longstatus As Long, longwarnings As Long
'Option Explicit
Dim xlRange As Object
Dim swCustPrpMgr As SldWorks.CustomPropertyManager
Dim xlApp As Object
Dim xlSheet As Object
Dim xlBooks As Object
' Open Excel workbook
Sub Main()
Set swModel = swApp.ActiveDoc
Set xlApp = CreateObject("Excel.Application")
xlApp.Visible = True
xlApp.Workbooks.Open "C:\STOCKED INVENTORY LIST.xls"
Set xlSheet = xlApp.ActiveSheet
' Copy data from Excel to Custom Properties
' Set xlApp = GetObject(, "Excel.Application")
' Set xlSheet = xlApp.Sheets(1)
Name = xlSheet.Cells(8, 9)
swModel.DeleteCustomInfo2 "", "RawPartNo"
swModel.AddCustomInfo3 "", "RawPartNo", swCustomInfoText, Name
Name = xlSheet.Cells(9, 9)
swModel.DeleteCustomInfo2 "", "RawOperation"
swModel.AddCustomInfo3 "", "RawOperation", swCustomInfoText, Name
' Close Excel
xlApp.Workbooks.Close
xlApp.Quit
x 1225
x 2391
Re: How to Paste a property value inside of an excel cell
ResidentAtLarge wrote: Fri Jun 18, 2021 2:50 pm I am pretty new to the API with very little programming experience.
I've looked at the solidworks API Help and I am not sure on which co...
@ResidentAtLarge , we have code tags you can use for code in the main editor. I fixed this one.
gupta9665
Answers: 26
x 445
x 471
Unread post by gupta9665 »
You just need to use the reverse of below line
i.e.
 xlSheet.Cells(8, 9) = "Your desired value here"
ResidentAtLarge
x 30
gupta9665 wrote: Sun Jun 20, 2021 12:21 pm You just need to use the reverse of below line
i.e.
As someone new to programming, I did not think to reverse it the way you put it. But, this is the correct way to do it. I have successfully got this script to work the way I wanted it to.
I used the API help to find the correct way to copy a custom property here: http://help.solidworks.com/2017/english ... Redirect=1
Thank you Gupta!
