How to display exploded lines
Posted: Thu Jul 15, 2021 2:57 pm
by Uncle_Hairball
What's the trick to display exploded lines in a drawing?
Re: How to display exploded lines
Posted: Thu Jul 15, 2021 3:08 pm
by mike miller
RMB on the exploded view derived configuration and select "Smart Explode Lines". They should then be visible in the exploded drawing view.
2021-07-15 15_05_50.jpg (69.04 KiB) Viewed 3233 times
Posted: Thu Jul 15, 2021 3:32 pm
by Uncle_Hairball
mike miller wrote: Thu Jul 15, 2021 3:08 pm RMB on the exploded view derived configuration and select "Smart Explode Lines". They should then be visible in the exploded drawing view.
Thanks for the suggestion, Mike, but I don't seem to have that option.
Since I posted the question, the lines magically appeared. Must be some sort of regen problem, as I didn't do anything to make them appear. Unfortunately, all my manual regens didn't make anything happen, but after ignoring it for a while, SW figured it out on its own.
Posted: Mon Jul 19, 2021 11:41 am
by oldguynewbike
If you have already added them and are simply waiting for them to show up on the drawing when opened or switching between sheets I have seen it take up to a minute for them to "reappear" especially on a large assembly.
Posted: Mon Jul 19, 2021 12:25 pm
by Uncle_Hairball
oldguynewbike wrote: Mon Jul 19, 2021 11:41 am If you have already added them and are simply waiting for them to show up on the drawing when opened or switching between sheets I have seen it take up to a minute for them to "reappear" especially on a large assembly.
Crazy
