I finally got this Part to work, but it was a struggle.
After using the Structural Member function to create both ends I tried every way I could think of to Loft between them. I admittedly go months without needing to do a Loft, but I think I tried every possible setting and kept getting this error.
I finally created a Surface Loft (and I use Surfaces much less than solid Lofts) and thickened it, which worked, but it seems like there should be a better way. Any ideas?
Better way to do this?
- x 1759
- x 2132
- Thrie to W-Beam, asymmetric.SLDPRT
- (891.93 KiB) Downloaded 57 times
Re: Better way to do this?
This is similar to your previous question on the old forum, for a symmetric version:
https://r1132100503382-eu1-3dswym.3dexp ... NiraOD2n3A
The error message was different, but it might be worthwhile to match up the segment count between the ends and see what happens.
- x 1759
- x 2132
Thanks Jim,JSculley wrote: ↑Fri Jul 23, 2021 11:17 am This is similar to your previous question on the old forum, for a symmetric version:
I thought I remembered a similar issue, but wasn't sure I had posted it before, and in any case I haven't spent a week on the other forum learning to do a search so I probably wouldn't have been able to find it anyway.
I pulled up that file (which I still use), and I did add a sketch with enough end points to make the same number of segments as the larger end, but I seem to remember someone (I think it was @matt ) saying the necessity of having an equal number of segments wasn't that important, but maybe I was wrong.
I made everything with surface: Both profiles with Extrude Surface, then connected them with Boundary Surface (or Loft Surface - Loft is better if you want to add more profiles to guide the changes in the surface).Glenn Schroeder wrote: ↑Fri Jul 23, 2021 10:23 am I finally created a Surface Loft (and I use Surfaces much less than solid Lofts) and thickened it, which worked, but it seems like there should be a better way. Any ideas?
- Guardrail_surface.SLDPRT
- (13.11 MiB) Downloaded 65 times
Or maybe you want to do with features and keep structural members. It is possible to do with Boundary Feature: Select the faces and apply tangency.
And with Loft Feature:
- Guardrail_feature-loft.SLDPRT
- (1.03 MiB) Downloaded 49 times
- Guardrail_original.SLDPRT
- (1.25 MiB) Downloaded 71 times
Completely off topic but I love when people post things like this. I found myself looking at guard rails back and forth from work and looking for this pieceGlenn Schroeder wrote: ↑Fri Jul 23, 2021 10:23 am I finally got this Part to work, but it was a struggle.
- x 1759
- x 2132
That piece is typically used off the end of bridge or overpass concrete parapets. Thrie-beam guardrail (usually two pieces nested one inside the other) is attached to the parapet, and that piece is then used to transition to standard W-beam guardrail.
Without that transition mean nasty things would happen if someone hit the relatively flexible W-beam near the concrete, which is of course rigid.
Not surprisingly that's where the ones I say whereGlenn Schroeder wrote: ↑Thu Jul 29, 2021 10:19 am That piece is typically used off the end of bridge or overpass concrete parapets.
