Hello,
I am working on a tool to help us dissolve some of our configured part files into files, each with one config. So instead of having n part numbers in 1 file we’ll be back to having 1 part number per 1 file.
I have not done much with configurations and I’m trying to find how to more or less copy a derived config back to the Default config. Or edit the Default config to be identical to a specific derived config. I think I’m looking for it in all the wrong places, I don’t even have a start. I'm getting the feeling that what I'm trying to do goes against the normal configuration operations.
Making “Default” config identical to one other existing config
If you were doing this manually, you would have to activate the derived config, add a new config with a different name than 'Default', delete the 'Default' config and then rename the new config to Default.
Go to full postRe: Making “Default” config identical to one other existing config
that's way too simple. I'm going to spend a couple more days trying to figure out a more elaborate way of doing this.
What you said to do written in C#, fast and simple:
swModel.AddConfiguration3("_Default", configNameToKeep, "", 0);
swModel.DeleteConfiguration2("Default");
Configuration c = swModel.GetConfigurationByName("_Default");
c.Name = "Default";
