Cursor Tracking Problem when entering a sketch
- x 1
As you can see from the image attached, there are lines in the x and y directions that follow the cursor when i select a sketch shape.
- another example[146].pdf
- (1.6 MiB) Downloaded 67 times
- solid edge cursor problem forum submissi.pdf
- (3.68 MiB) Downloaded 64 times
- x 1
Re: Cursor Tracking Problem when entering a sketch
Any advice is welcomed. I truly dont know where to start to fix this
I'm guesting that you have an NVidia graphics card?
Regardless, I suspect that you do not have the latest graphics driver for you graphic card. Update your driver with the latest available from the graphics vendor not from the computer manufacturer.
- x 1633
- x 2044
See if anything at https://www.cadforum.net/viewtopic.php?f=17&t=98 will help.
- Jaylin Hochstetler
- x 375
- x 353
I've had this happen when I was sketching a line or shape and I moved my 3D Mouse and my regular mouse at the same time.
