When I cancel the creation of a sketch/feature/whatever and restart it the naming system keeps increasing automatically (which makes sense), but I want it to overwrite the non-existing features.
Is it possible to do?
Manually renaming it fix the counting, but still is a boring practice.
Reset Feature name counting number
Re: Reset Feature name counting number
I agree it can be tiresome, there's a couple of habits you can foster to help but I think you are best not worrying about it too much and/or renaming to meaningful names.
Instead of cancelling, try undo.
If it's a small part you can reload the document quickly.
A macro is probably best solution
You can tidy up your tree with this macro: https://www.codestack.net/solidworks-ap ... uentially/ and after it should continue with the next available number as the index for new feature
Thanks,
Artem
Artem
Unfortunately Undo also increases the counting number
Usually I ignore it or start renaming from the beginning when I know it will be a complex part; but most of times it is a little complex and just bothers me to stop to fix it. lol
Thank you, worked fine here.artem wrote: ↑Fri Aug 06, 2021 2:31 am You can tidy up your tree with this macro: https://www.codestack.net/solidworks-ap ... uentially/ and after it should continue with the next available number as the index for new feature
May I ask any suggestion of site/reading to start learning Solidworks Macros? I just know basic programming and am postponing this.
- x 1759
- x 2130
My best suggestion is to ignore those numbers. I do it just fine. If you can't or don't want to do that, re-name the features, sketches, etc to something that actually describes their function or purpose instead of just using numbers.
- x 812
- x 979
Just rename Sketch4 to Sketch3. From then on, then next sketch will be Sketch4.Lucas wrote: ↑Thu Aug 05, 2021 9:27 pm When I cancel the creation of a sketch/feature/whatever and restart it the naming system keeps increasing automatically (which makes sense), but I want it to overwrite the non-existing features.
Try it out.
Usually I name it, but lots of parts is pretty useless to name everything and would be nice to have the names just in order .-.Glenn Schroeder wrote: ↑Fri Aug 06, 2021 8:15 am My best suggestion is to ignore those numbers. I do it just fine. If you can't or don't want to do that, re-name the features, sketches, etc to something that actually describes their function or purpose instead of just using numbers.
That's how I have been dealing with it. lol
thanks
