Fill up open path
christian chu
x 39
Fill up open path
Can someone help, pls.
I tried to fill up an open path and can't make it smooth to the side - see att. image
Thank you
PathIssue.SLDPRT
(196.63 KiB) Downloaded 83 times
x 1214
x 2368
Re: Fill up open path
You mean patch? What did you try to use?
x 1214
x 2368
The first picture is a boundary surface with curvature set at the edges. Not very good. The 2nd picture is the deviation analysis of the existing connections between faces. Pretty good where they need to be.
The 3rd picture uses a Fill surface where the open edge was closed by a 3d spline with equal curvature set on both ends.
christian chu
x 39
matt wrote: Fri Aug 06, 2021 5:26 pm The first picture is a boundary surface with curvature set at the edges. Not very good. The 2nd picture is the deviation analysis of the existing connections between faces. Pretty good where they need to be.
I already tried the 3rd option with a 3D Spline and filled surface
Still not very smooth
Lucas
x 171
x 169
Unread post by Lucas »
Here is what I got:
Boundary
Fill
I think we might need to trim something to get better results, but I don't know what is important to keep .-.
PathIssue - Fill.SLDPRT
(368.03 KiB) Downloaded 81 times
PathIssue - Boundary.SLDPRT
(333.87 KiB) Downloaded 110 times
x 1214
x 2368
To make this better, I'd go back and make sure the existing surfaces are as good as possible, and then make some additional control curves.
Lucas
x 171
x 169
Yep, or forget it all and just get the boundary that it fits with the guide curves. I checked what happens with Loft (forgot to use fit spline, SW in my laptop is jamming with this file) tu
PathIssue - Loft.SLDPRT
(364.88 KiB) Downloaded 88 times
christian chu
x 39
matt wrote: Sat Aug 07, 2021 6:48 am To make this better, I'd go back and make sure the existing surfaces are as good as possible, and then make some additional control curves.
Thank you for suggestion; however, this part is already in production which I'm not sure if the existing surface can be changed
christian chu
x 39
Lucas wrote: Sat Aug 07, 2021 7:30 am Yep, or forget it all and just get the boundary that it fits with the guide curves. I checked what happens with Loft (forgot to use fit spline, SW in my laptop is jamming with this file) tu
I'm still running SW2020; can't check the curvature but I can see from the att. image
zxys001
Answers: 5
x 2304
x 997
Unread post by zxys001 »
christian chu wrote: Fri Aug 06, 2021 5:01 pm Can someone help, pls.
Thank you
..a few ways I'd do it..
PathIssue z.zip
(687.21 KiB) Downloaded 107 times
