Circular Pattern
Maha Nadarasa
x 51
x 48
Circular Pattern
I replicate this part. In this video for circular pattern, surface of the part is detected by Direction1. But in my file it is not detected. How to fix it?
time 11.25 in the video
Leaf Pattern on Ring.SLDPRT
(3.86 MiB) Downloaded 102 times
x 1219
x 2381
Re: Circular Pattern
Detected? You mean defined? The only way you can use a face to define a circular pattern is if the face is a revolved face with a centerline. Is there a reason the people who made the video won't answer you?
It looks like you used a flex feature, which usually makes junk. You can't use a flexed face because it's not as accurate as analytical geometry - it's spline based approximations.
Maha Nadarasa
x 51
x 48
In the video it shows bend part using flex command works with circular pattern. It does not work for me. That is what I want to know.
x 1219
x 2381
Maha Nadarasa wrote: Fri Aug 13, 2021 2:14 pm In the video it shows bend part using flex command works with circular pattern. It does not work for me. That is what I want to know.
Yeah, don't believe everything you see on Youtube.
x 1219
x 2381
Ok, here's what's happening. At 10:55...
At this point he copies the radius that the Flex feature calculates for him.
Then he goes to the Axis command, but it doesn't show what he does. It looks edited.
I'd bet he made an axis or a revolved cut sketch and cut the inside face of the shape so it has a true revolved surface, and thus an axis.
Anyway, this is the same guy that lifted the motor model from one of my books to show in his videos and everybody is like oooh and ahhh over his model, but it's not his model at all.
Ask that guy the questions you've asked me and see what kind of response you get.
Maha Nadarasa
x 51
x 48
It detecting in the uploaded file in the GC.
Leaf Pattern on Ring (Grabcad).SLDPRT
(23.02 MiB) Downloaded 149 times
Maha Nadarasa
x 51
x 48
matt wrote: Fri Aug 13, 2021 2:29 pm Ask that guy the questions you've asked me and see what kind of response you get.
Problem is you can notice in the comment section of the video no one is raising this question.
x 1761
x 2132
matt wrote: Fri Aug 13, 2021 2:16 pm Yeah, don't believe everything you see on Youtube.
Well said. About the only SW youtube videos I'll even look at are the ones put out by the VAR's, though I'm sure there are other good ones out there. As seen here, there are a lot of bad ones.
x 1219
x 2381
Alright, well, I've got to make a little retraction. The Flex really did work and created a cylindrical surface. I've just learned not to use flex for anything you need to be accurate.
Your flex feature doesn't work, but I suppressed your Flex and made one of my own, and it worked. Now I did correct a little error you had. You had selected an incorrect edge for the Chamfer at the end, and that might have done something to it. But I recreated the Flex feature from scratch (didn't reselect items, just suppressed your Flex and created a new feature), and it works. I used an intersection sketch to see what kind of sketch element that face created. Your flex creates a spline, and his (and mine) create arcs. All of the numbers and selections were the same. The only difference I found in your models was that you had selected an edge of the inside face for that chamfer. Fixing the chamfer didn't fix the flex, but a new flex did. I couldn't recreate your error, either. So I'm not sure what caused it, it might have been a round off error out past 3 or 4 places. I think if you delete your flex, fix your chamfer, and make a new flex, it will be correct.
x 1219
x 2381
Maha Nadarasa wrote: Fri Aug 13, 2021 2:38 pm Problem is you can notice in the comment section of the video no one is raising this question.
No one is asking him why he is using my model and pretending it's his, either, are they? And yet that's what he's doing. Not that I'm bitter about it.... :roll:
The motor isn't even that great of a model, I just made it as an example, and didn't have a week to do it. He didn't put any effort into it at all except right click, save as. It even shows some of the mistakes I left in there... Lazy liars really burn me up. :shock:
Maha Nadarasa
x 51
x 48
I did it different way.
Leaf Pattern on Ring-MW.SLDPRT
(18.71 MiB) Downloaded 102 times
x 1219
x 2381
Maha Nadarasa wrote: Fri Aug 13, 2021 3:37 pm I did it different way.
Yeah, that's the way I thought he did it at first. Second choice was that he made a cylindrical cut, extrude or replace face.
