BOM won't update material
Posted: Mon Aug 23, 2021 5:30 am
by jayar
I've got a BOM on a sheet and the part didn't have a material assigned originally. I opened the subass'y then the part and added the material to the part. Updated & saved the part, updated & saved the subass'y. Went to my sheet - still no mat'l. Updated the drawing - same thing. Verified that material was on the part, restarted - still the BOM won't update to include material for that part. What am I doing wrong?
Re: BOM won't update material
Posted: Mon Aug 23, 2021 7:31 am
Check the part properties and see if there is anything in "Configuration Specific." That seems to override the "Custom" tab. I've found SW will fill in the Configuration Specific table when I do a "Save As" on a part.
Posted: Mon Aug 23, 2021 9:28 am
by BuseHase
You can also try to use "restore original value" on the specfic cell of your BOM.
Posted: Mon Aug 23, 2021 10:23 am
Is your Material linked to a custom property that is in turn linked to in the BOM?
Posted: Tue Aug 24, 2021 12:29 am
by jayar
BuseHase wrote: Mon Aug 23, 2021 9:28 am You can also try to use "restore original value" on the specfic cell of your BOM.
Thanks, I tried that but it didn't work.
Posted: Tue Aug 24, 2021 1:36 am
by jayar
SPerman wrote: Mon Aug 23, 2021 7:31 am Check the part properties and see if there is anything in "Configuration Specific." That seems to override the "Custom" tab. I've found SW will fill in the Configuration Specific table when I do a "Save As" on a part.
Didn't find anything like that, thanks.
Posted: Tue Aug 24, 2021 1:40 am
by jayar
Glenn Schroeder wrote: Mon Aug 23, 2021 10:23 am Is your Material linked to a custom property that is in turn linked to in the BOM?
Well, that might have been part of the problem. I went in to the properties and added Material to the list & entered what I wanted. That seems to have done the trick.
