intersection extrude in solid edge
Damianes
x 7
x 5
Unread post by Damianes »
Hi all its my first porst :)
someone knows how to do this : 7:05
but on solid edge ?
it seems its not poseable in SE do I'm right ?
x 2456
x 1333
Re: intersection extrude in solid edge
Not sure, but it looks like they've combined the Extrude and Boolean Common features into one op. So to answer your question, yes that can be done in nearly every other CAD system, it will just take extra steps. IMO Inventor extrude and revolve features UI options have been ahead of the other parametric modelers for years. I don't know when it started but IIRC Inventor didn't care what type of extrude it was, they all had the same feature and could be edited later. Surface, solid, thin, cut, add; didn't matter all the same feature. That was very nice. I'm not surprised to see they took the next step and added Boolean operations right into the feature options now.
KennyG
x 43
x 178
Unread post by KennyG »
You can do the exact same thing in Solid Edge using the Extrude command with the Cut option and setting the cut side to the outside (defaults to inside for a closed sketch).
Imics13
x 40
x 98
Unread post by Imics13 »
Hi @Damianes,
Yes, it is easy as @KennyG has mentioned!
Here is a short video:
BR,
BR,
