SW PDM standard license
- christian chu
- x 31
- x 39
I have both SW and SWPDM server upgraded to 2022
Tried to login the Vault and got the err - see att. image
Any idea what it is
Any idea what it is
@christian chu Did you update the license manager server software to 2022?
Go to full postRe: SW PDM standard license
Did you select the correct options on install? I think by default it install PDM pro. I remember having to make explicit choices to get PDM standard instead of Pro, but I can't provide any specifics without going through the install process.
- christian chu
- x 31
- x 39
Yes, I selected "standard" when installing it
- x 1138
- x 1945
Along the same theme, did you upgrade your SQL database with the upgrade tool? There's a fair bit of configuration that needs to be done to the database side in order to make it compatible with all the new features of a PDM upgrade. Although, I can't remember if it would let you connect to the vault if the versions don't match.jcapriotti wrote: ↑Mon Oct 17, 2022 12:42 am @christian chu Did you update the license manager server software to 2022?
- christian chu
- x 31
- x 39
yes, I used this help linkAlexB wrote: ↑Mon Oct 17, 2022 9:33 am Along the same theme, did you upgrade your SQL database with the upgrade tool? There's a fair bit of configuration that needs to be done to the database side in order to make it compatible with all the new features of a PDM upgrade. Although, I can't remember if it would let you connect to the vault if the versions don't match.
https://support.hawkridgesys.com/hc/en- ... oc19890589
- christian chu
- x 31
- x 39
I got error mesg while upgrading the license managerjcapriotti wrote: ↑Mon Oct 17, 2022 12:42 am @christian chu Did you update the license manager server software to 2022?
- x 1138
- x 1945
- christian chu
- x 31
- x 39
