I inserted multiple subassemblies and mated to another component using path mates.
(I am modeling sliding door system with multiple door leaf. so Subassembly = each door leaf, mated to component = sliding track)
All subassemblies mated with different paths. I wanted these subassemblies to move along in its individually different paths.
But I found these subassemblies would be stuck and not move when I drag them,
found the reason to be because multiple mates were addressing to the same parts in subassemblies, and therefore conflicted.
Subassembly1
- part1
Subassembly2
- part1
Subassembly3
- part1
as such structure....
So now I know the problem, but how to solve it efficiently?
If it's only 2 or 3 subassemblies, I could manually change file path or file name, so they are technically different parts... But what if I have far many of them?
How to properly insert multiple sub-assemblies
Re: How to properly insert multiple sub-assemblies
Not sure if I got it. The subassemblies cant move in the assembly file due to the mates inside of it, so you have to save one part with different names to fix it?
I think you could do it using Pack and Go
https://help.solidworks.com/2019/englis ... 27efb2#Pg0
- x 1645
- x 2054
I know you said "I know the problem", but I'm not sure you do. I know I don't. Using the same Part in multiple sub-assemblies shouldn't cause any mating problems in the upper level Assembly. Can you do a Pack and Go of the Assembly to a zip file and post it here?
You can download from this link:Glenn Schroeder wrote: ↑Mon Sep 13, 2021 8:14 am I know you said "I know the problem", but I'm not sure you do. I know I don't. Using the same Part in multiple sub-assemblies shouldn't cause any mating problems in the upper level Assembly. Can you do a Pack and Go of the Assembly to a zip file and post it here?
I put in 2 door leafs using path mates.
If I suppress mating for one of these doors, the other door leaf will slide just fine.
I have no idea what the issue is with your exact situation but I do know that I've had a LOT of issues with path mates. I've done a couple of projects where I had "Garage door" type of assemblies and it would NEVER fail that the path mate would either blow up or just lock up.osh5110 wrote: ↑Sat Sep 11, 2021 12:01 am I inserted multiple subassemblies and mated to another component using path mates.
Subassembly1
- part1
Subassembly2
- part1
Subassembly3
- part1
My approach typically ends up a couple ways. Do the path mate for design purposes only. In other words path mate it and check what you need to along the path. Create another config that suppresses the path mate and mate the actual working assembly using other mates in a few critical positions for designing, drawings etc.
Yeah, you are right. If I suppress one door the other can move much better. lol
Looks like you created the Path Mates properly, I think SW has a problem to find the pivot in this situation.
I would suggest you to forget about dragging the structure and create Configurations for the assembly, one open and other closed. (You could create more configurations with the doors in specific positions for presentations)
Btw, the way the roller leg is designed might not allow the door to slide on the joints:
