How to improve the speed of SW selection API?
Or To avoid the SW selection API, Implementation SW DeriveSketch API?
The development process encountered efficiency issues. Need help! Thinks!
Re: How to improve the speed of SW selection API
Try to use the API only selection: https://www.codestack.net/solidworks-ap ... selection/
or batch selection: https://www.codestack.net/solidworks-ap ... t-objects/
Thanks,
Artem
Artem
Thanks,
Has been used Try to use the API only selection or batch selection,
But it's still slow.
Is there any other way?
turn off graphics update
Are you working in assembly? If so you might want to disable this option as it significantly affects the performance while selecting for large assemblies: https://www.codestack.net/solidworks-ap ... into-view/
Thanks,
Artem
Artem
Thanks,
The speed of selection is greatly improved when the Scroll selected item into view is disabled,
but the speed is still not up to standard when there are too many parts.
Currently disabled:
Graphics update
FeatureTree and FeatureTreeWindow
AssemblyRebuild
Currently disabled:
Graphics update
AssemblyRebuild
- x 289
- x 56
Have you tried artem's suggestions above? I.e. Bath selection and/or API-only selectionz1282407454 wrote: ↑Mon Feb 21, 2022 3:10 am Thanks,
Currently disabled:
Graphics update
AssemblyRebuild
Austin
Yes, used, currently used is AddSelectionListObjectsAustin Schukar wrote: ↑Mon Feb 21, 2022 11:05 am Have you tried artem's suggestions above? I.e. Bath selection and/or API-only selection
