Sweep Cut Curved surface Will do single but not multiple
OldOZNoob
Unread post by OldOZNoob »
Hello,
Trying to multiple sweep cuts across a face like below. Allows a single cut but the face needs about 90 repeated going left to right on the concave surface.
Error message comes back
But it will do a single?
Lost as I performed the exact same task on a convex surface yesterday with no issues. Also it will let me enter each cut individually if i put it on a new sketch each time, but im not doing that.
Please help.
Ol Oz
zxys001
Answers: 5
x 2305
x 998
Re: Sweep Cut Curved surface Will do single but not multiple
Unread post by zxys001 »
Hi OldOZNoob, can you share the file?
OldOZNoob
Hi Zx,
Hope this works !
Never shared a file :)
You can see the first one. Just trying to repeat that across the entire concave.
NEW METHOD CONCAVE.SLDPRT
(162.09 KiB) Downloaded 45 times
AlexB
Answers: 28
x 269
x 446
Unread post by AlexB »
I took a look at this just to be sure because I figured this is caused by zero-thickness-geometry.
A sweep-cut is a boolean operation so it subtracts the "solid" you're making with your sweep from the existing solid. I manually performed that operation by creating your sweep as a solid and patterning it across the length. When I use Combine -> Subtract, I get this error.
My advice is to do one of the following:
1) Get rid of this point in your sweep profile pattern.
It needs to be a single enclosed profile (in most cases)
2) Your sweep needs to be made up of many single sweep operations (not really a good practice)
TTevolve
x 86
x 161
Unread post by TTevolve »
Make it a revolve cut and pattern it. I had to add extra reference geometry because you didn't start off the standard planes as the center and nothing was locked down. But it should work better.
(780.35 KiB) Downloaded 64 times
I would not use a sweep unless I had to, usually when the profile needs to change path in all 3 directions. Patterns will regenerate faster.
OldOZNoob
Thank you very much TT Evolve that's a great help.
@Alex B I'll give that a try also.
Thanks for posting Zx, these chaps have sorted it.
Cheers everyone!!
Old Oz
FTUMCH
x 5
Unread post by FTUMCH »
Cool handle oldoz
GDay from sunny Perth
woldentbededforquids
