Find specific property in drawing sheet format and change the content
gt.adan
x 3
Unread post by gt.adan »
Hi everyone. My question is as follow :
There is a linking property named $PRP:"SW-File Name" in EVERY drawing sheet format. Is it possible to get it and change the content to certain words or to custom property like $PRPSHEET:"Customer Spec" via VBA? Any idea is welcomed.
by gupta9665 » Tue Nov 07, 2023 3:21 am Go to full post
gt.adan
x 3
Re: Find specified property in drawing sheet format and change the content
Not one reply!? It's a little bit frustrated... :( Maybe I didn't express my problem clearly.
This work can be accomplished by batch replacing sheet formats. But I cannot do it because there are some properties in the drawings linked to specific view name. Further more, there are some drawings contain more than 2 pages.
Once again, any help is appreciated~
josh
Answers: 11
x 19
x 456
Unread post by josh »
OK... You have asked if it is possible... Yes, it's possible.
Are you actually asking someone to do it for you?
x 2191
x 1892
It's not very clear to me what you are trying to achieve, so that could be a reason why people are hesitant to answer.
Why would you want a manual entry rather then use the existing ones? Do you understand the entries and what they link?
josh
Answers: 11
x 19
x 456
I believe he's looking for a "Find-Replace" in annotations, except that it works for notes linked to properties rather than just looking at the displayed text.
Answers: 24
x 755
x 907
josh wrote: Mon Nov 06, 2023 3:56 pm I believe he's looking for a "Find-Replace" in annotations, except that it works for notes linked to properties rather than just looking at the displayed text.
Artemis' #TASK would do this, I think. I don't think that it works any more though.
gt.adan
x 3
Hello Alex. Please forgive my bad English. I've been using SW for more than 10 years, so yes, I know the entries and what they link.
Actually, what I want is to replace "$PRP:"SW-Folder Name"" with "$PRPSHEET:"Customer Spec"" in the sheet format, not the "File Name" I mentioned before.
Older drawings show the full path name in the customer specification field, which is the link "$PRP:"SW-Folder Name"", but the displayed text is too long. Now I create a new template, use simple code to extract the spec information I need, and write it into the custom property, which is the link "$PRPSHEET:"Customer Spec"".
The new template works well and has been running for a while, but I have to go back and work on the old projects.
There are so many drawings to process, but they are just repetitive actions. I know this job can be done using VBA code batch processing, but I'm still very new to programming, so came here to ask for help.
gt.adan
x 3
josh wrote: Mon Nov 06, 2023 11:00 am OK... You have asked if it is possible... Yes, it's possible.
Hi, Josh, thanks for the reply, but I'm not here to ask someone to do it for me.
In fact, I did some research. I used the information on the Internet and my very shallow knowledge of VBA to write some code, but I always failed. That's why I'm here for help. What I need to replace is the link in the sheet format rather than the drawing, but the following code always shows that it cannot be defined. I am still working on it.
gupta9665
Answers: 20
x 384
x 417
Unread post by gupta9665 »
gt.adan
x 3
Hi, Deepak. Thank you for the three links you provided, I will read them carefully later. I believe I can get helpful information from them.
gt.adan
x 3
@gupta9665
I modify the code you provided in the 3rd link, and it works perfect!
I've always thought that the code for replacing properties in a sheet was different than the code for replacing properties in a sheet format.
Thank you again~ Here is the code
Option Explicit
Sub main()
Dim swModel As SldWorks.ModelDoc
Dim swView As SldWorks.View
Dim swNote As SldWorks.Note
Set swModel = swApp.ActiveDoc
Set swDraw = swModel
Set swView = swDraw.GetFirstView
While Not swView Is Nothing
Set swNote = swView.GetFirstNote
While Not swNote Is Nothing
If swNote.PropertyLinkedText Like "$PRP:""SW-Folder Name(Folder Name)""" Then
Debug.Print "Replacing " & swNote.GetText & " (" & swNote.PropertyLinkedText & ")"
swNote.PropertyLinkedText = "$PRPSHEET:""Customer Spec"""
End If
Set swNote = swNote.GetNext
Wend
Set swView = swView.GetNextView
Wend
