If you're thinking about getting an electric car . . .
For things you would put in a kitty dump.
x 1758
x 2129
. . . you might want to watch this video of a test we did a couple weeks ago. Please note that this is a Thrie-beam rail, which is made of the same material as a standard W-beam rail, except it has one more rib, so it's about 8" wider. A standard W-beam will redirect a passenger car or a 1/2 ton 4-door pickup with an internal combustion engine, so this is a stronger rail than what's typically used on roadways.
I suspect that the testing standards will need to be modified as the number of electric vehicles on the road increases.
https://www.youtube.com/watch?v=PFen-_R_0Mo&t=4s
VicFrauenfeld
x 82
x 80
Re: If you're thinking about getting an electric car . . .
Unread post by VicFrauenfeld »
Wow Glenn. Could you share a video of an internal combustion engine car? I am just curious what the difference is. Do you think the electric one does not redirect because the weight being so low in the vehicle (where the battery pack is located), it just seems to snap the wooden posts.
x 2361
x 2011
Kinda scary how the rail bends in an angle directly to the windshield upon breaking.
x 2224
x 1874
I assume it is the total weight of the vehicle.
https://www.evspecs.org/electric-cars-w ... ison-chart
The Tesla X weighs 2000 lbm more than an Accord. (And that accord is probably a hybrid with extra batteries of its own.)
There are so many negatives to EV's that aren't even part of the discussion, but should be. I'm not anti EV, but I'm anti being lied to.
x 1636
x 1467
SPerman wrote: Wed Jul 10, 2024 8:59 am I assume it is the total weight of the vehicle.
Yeap. A sedan heavier then a truck and very low CG.
We need 360 Matrix shots oa
DennisD
x 1031
x 1467
Unread post by DennisD »
You are well grounded with your unintended pun!
- - -Randy Pausch
KennyG
x 44
x 196
Unread post by KennyG »
@Glenn Schroeder What gauge is the sheet metal that is formed from?
x 1758
x 2129
VicFrauenfeld wrote: Wed Jul 10, 2024 8:47 am Wow Glenn. Could you share a video of an internal combustion engine car?
Here you are. I don't have access to any film of a specific test with one, but this video has two similar tests where the goal was to contain the vehicle. The first one (starting at about the 9:00 mark) is impacting W-beam, which as I mentioned above is a narrower rail than the one in the electric car test, and the one right after it is a box van impacting Thrie-beam.
By the way, the structure being impacted in the last test in this video, starting at about 12:00 minutes, is one of the first projects I worked on when I started with SW (with no previous modeling or drafting experience). As you might imagine, I breathed a big sigh of relief when it all fit together like it was supposed to.
https://www.youtube.com/watch?v=_XXJqEY-sXk
x 1758
x 2129
KennyG wrote: Wed Jul 10, 2024 10:16 am @Glenn Schroeder What gauge is the sheet metal that is formed from?
Twelve gauge.
KennyG
x 44
x 196
Glenn Schroeder wrote: Wed Jul 10, 2024 11:51 am Twelve gauge.
That's pretty heavy.
x 1758
x 2129
I forgot to mention that the impact speed for that test was only 62 mph (100 kph).
ctsturdiv
x 49
x 68
Unread post by ctsturdiv »
Glenn Schroeder wrote: Wed Jul 10, 2024 8:21 am . . . you might want to watch this video of a test we did a couple weeks ago. Please note that this is a Thrie-beam rail, which is made of the same material as a standard W-beam rail, except it has one more rib, so it's about 8" wider. A standard W-beam will redirect a passenger car or a 1/2 ton 4-door pickup with an internal combustion engine, so this is a stronger rail than what's typically used on roadways.
You are making me re-live Physics.
I can imagine.
Just the extra mass on those huge battery packs on something like a Tesla an unstoppable force, especially with the center of gravity of that mass so low to the ground.
But, my question is that you have much heavier machines on the road like big semi trucks. Is it that these barriers were approved beforehand because the barriers can usually handle the mass at that velocity if the center of gravity is higher up?
I personally am not a fan of EVs (especially Teslas) because of range, cost, and horrible customer service/repair concerns. Anything goes wrong with these, you look at multiple thousands and months backlog to fix at a place that may be hundreds of miles away. I also think there may be some fraud involved. If you call something "full self driving" it should mean "driving by itself". That is near some Theranos level trickery there and I think Musk dd it just to manipulate stock prices when he knew all he had was a more advanced form of cruise control. How many big employers would LOVE to not have to pay drivers if this were true. But at least unlike Elizabeth Holmes, a Tesla still drives, so he gets somewhat of a pass. But still think some regulatory body needs to look into this and require Tesla to let other people work on their cars.
x 1636
x 1467
Looks like it went under the rail.
x 1758
x 2129
ctsturdiv wrote: Fri Jul 12, 2024 9:18 am But, my question is that you have much heavier machines on the road like big semi trucks. Is it that these barriers were approved beforehand because the barriers can usually handle the mass at that velocity if the center of gravity is higher up?
The current testing standards for roadside barriers were established about 15 years ago, so before there were many electric vehicles on the road. That barrier would not stop a semi truck, but if you watched the second video I posted you will see that it will stop smaller trucks (what we generally refer to as box vans).
You need a concrete barrier to re-direct a loaded semi truck (42" tall, if I remember correctly).
x 1758
x 2129
We (along with other similar testing labs) made the national news. See https://www.cbsnews.com/news/electric-v ... -barriers/. Our test is the one at about 2:30 in the video.
Also, if that isn't enough, one of my sister-in-law's neighbors house flooded during the hurricane last week, with a Tesla parked in the garage. Apparently salt water is pretty good at conducting electricity. The part of the house that wasn't under water burned up.
RichGergely
x 109
x 156
Unread post by RichGergely »
Taking away the barrier issue riding under or over, a car smashed to bits at the front in a crash is usually a reasonable good sign in a crash test. The crucial bit is keeping the occupants safe inside and all the crumple zones taking the impact without forcing objects into the passenger area.
retonny77
x 6
Unread post by retonny77 »
The maintenance side of things does make me a bit hesitant. It seems like the whole service model still has a long way to go before they really become mainstream. I guess we'll have to wait and see how the industry adapts!
Tera
x 483
x 91
Unread post by Tera »
A while back, all platforms of social media was filled with this test by a Chinese company.
