Drawing formats
CarrieIves
x 376
x 136
Drawing formats
Unread post by CarrieIves »
We are slowly merging two companies together. One has "DO NOT SCALE DRAWING" as part of the drawing template/format. One does not. How many of you are still adding that phrase on your drawings?
MattW
x 5
Re: Drawing formats
Unread post by MattW »
It isn't on ours.
A related question is how many people are left that even could scale a drawing, and how long since it would have been considered acceptable practice?
Tera
x 483
x 91
Re: Drawing formats
Unread post by Tera »
If all necessary dimensions are on the drawing, why should someone try to scale it?
Not on ours either.
DennisD
x 1031
x 1467
Re: Drawing formats
Unread post by DennisD »
I think according to ASME Y14.5 that all drawings should have that note.
- - -Randy Pausch
x 2224
x 1874
Re: Drawing formats
I am also curious if anyone still has the sheet size on their drawings. It seems unnecessary given that most prints are delivered in digital formats these days, and you can't control what size sheet they print it on.
I have both in my title block, because when I created our first print I copied something that looked generic and industry standard.
CarrieIves
x 376
x 136
Re: Drawing formats
We have sheet size, which I found helpful as long as it isn't the most bold thing in the title block. It looks like ASME Y14.1-2005 says to have the sheet size. (That's what I have a copy of)
It didn't talk about the note "DO NOT SCALE DRAWING".
RichGergely
x 109
x 156
Re: Drawing formats
Unread post by RichGergely »
A drawing wouldn't be a drawing without that old time note on it.
Drawings, well I'm actually doing some at the moment. First time in over 4 years, everyone else didn't want them anymore.
HercalloY
x 43
x 32
Re: Drawing formats
Unread post by HercalloY »
Yes i have it on drawings and i see it on many that i receive. Thankfully. I also include sheet size on drawings. This is also a vital bit of information when other information is missing to help one resolve issues. Just because you don't see a point it in... doesn't mean it isn't helpful when its photocopied 8 times, screenshot, saved into a .jpg and then printed out and "scanned" in and 30 years late your have to make a component on it, doesn't mean its not helpful.
x 2224
x 1874
Re: Drawing formats
I'm confused by your answer. Are you saying you have "do not scale" on your drawings, and then saying that knowing the sheet size is helpful if you need to scale the drawing?
DavidWS
x 26
x 12
Re: Drawing formats
Unread post by DavidWS »
I've got both size and scale on our drawing in this format:
Also in the TB states CAD GENERATED DRAWING, DO NOT SCALE as well as IF IN DOUBT, ASK!
RichGergely
x 109
x 156
Re: Drawing formats
You also have the UOS note often on scale.
HercalloY
x 43
x 32
Re: Drawing formats
SPerman wrote: Sat Nov 02, 2024 6:12 am I'm confused by your answer. Are you saying you have "do not scale" on your drawings, and then saying that knowing the sheet size is helpful if you need to scale the drawing?
Don't be confused. Scaling is sometimes required to get an idea of an assembly or part when one is deciphering a drawing. The note is for when you need to verify something other then just gaining comprehension of a drawing's scale at first blush. i.e. to get actual required sizes one would follow the note and ask but is not required when one is simply wrapping their head around a complex or unclear drawing. This is also greatly used when, as i mentioned, people often duplicate drawings or have had them for long periods by those that care very little for retaining quality and/or when scales are excluded due to providing only certain areas of a full drawing and not the tittleblock etc Having a drawing sheet's size listed is yet another bit of information that takes nothing to include but can mean a lot in many scenarios.
I know you are probably trying to create a "gotchya" by implying that i'm putting both on a drawing then contradicting it but that is completely short sighted on your behalf because you can create drawings with "DO NOT SCALE" and also receive drawings from many others without the note and having a drawing's sheet size is immensely helpful. So both can be true at the same time. But, as mentioned, even when the note exists on drawings, scaling can often be helpful to gain understanding and comprehension of complex drawings.
Answers: 30
x 1202
x 1992
Re: Drawing formats
We have a note in the TB "CAD Drawing - Do Not Scale". We don't put sheet size or scale on the print. Last we only use "A" and "B" size drawing templates. Been this way since the mid 90s.
Reasoning I believe is once 11 x 17 printers became common in the mid to late 90s, our blueprint room went away and all drawings were viewed and printed from an internal system in "TIFF" format. We had a few "C" and "D" drawings and when printed on 11x17 they were hard to read, so gradually they were all replaced.
Sheet size was redundant as we only now had "A" portrait drawings and "B" landscape drawings and its easy to distinguish.
Regarding scale on the print, out factory preferred 1 sheet drawings when possible so we had to sometimes cram a lot information into one page. This meant scaling the views to non standard scales to make stuff fit. So a scale of 1:5.5 would be more confusing than helpful.
