Conditional notification option disappeared
Posted: Fri Sep 24, 2021 11:30 pm
by revenki
I've been building a new workflow over the past week. In the process, I discovered conditional notifications, and added one to one of the transitions to test it out. It worked, and I decided to add it to transitions in a couple of other workflows.
Only, the option is no longer there. I only have the options to Add Folder Notification, Remove Notification, and Edit Notification.
I know I wasn't imagining things, as the one I created as a test is still there. But even in that transition, the Add Conditional Notification is gone.
Is there a setting or the like that I may inadvertently disturbed that would account for this? How do I make it available again?
(Using Enterprise PDM 2019 SP5, build 27.5 (B77).)
Re: Conditional notification option disappeared
Posted: Tue Sep 28, 2021 6:23 pm
Make sure you are selecting the transition and not the state. The state notifications only show the 3 you mentioned.
Posted: Sun Nov 21, 2021 12:35 am
by revenki
Following up on this:
I talked to our VAR, and they said conditional notifications disappearing is a bug peculiar to 2019 SP5.
I ended up programming my own email VBS that I can execute as a command on transition. Which is a better option, as the content of the conditional notification isn't useful or descriptive anyway.
