Feature and Sketch not under one another?
Posted: Tue Oct 12, 2021 8:51 am
Hi,
I have an Extrude Cut Feature that the sketch somehow let me drag the sketch out from under it like you would normally see, how do I get it back under the feature it created?
as you can see the 40 degree cut extrude has nothing under it when I try to expand the tree (should have Sketch196)
in the past I have seen this happen and no idea on how to correct it or make it like you would normally see other than delete the feature and redo
Regards,
Jim
Regards,
Jim
