Feature and Sketch not under one another?
JMOS4
x 12
Unread post by JMOS4 »
Hi,
I have an Extrude Cut Feature that the sketch somehow let me drag the sketch out from under it like you would normally see, how do I get it back under the feature it created?
as you can see the 40 degree cut extrude has nothing under it when I try to expand the tree (should have Sketch196)
in the past I have seen this happen and no idea on how to correct it or make it like you would normally see other than delete the feature and redo
Regards,
Jim
x 1231
Re: Feature and Sketch not under one another?
You probably pressed Ctrl+T and activated Flat Tree Display. Press it again and it will include consumed features under the children.
JMOS4
x 12
Hi again,
Tried the Control T and it puts all the features and sketches apart but when I toggle it back nothing changes
CTRL T:
CRTL T again
seems to be only on that one feature, was fine after I created it and had a pattern I was trying to drag up in a folder and all of a sudden noticed this
Regards,
Jim
Lucas
x 171
x 169
Unread post by Lucas »
I have tried to replicate this, but only could let it be unabsorbed using the freeze bar.
Maybe it is due to the parent relation in the feature or maybe a bug? I didn't find a way to unabsorb one specific sketch :/
