How to identify the "parent" of a Centermark?
loeb
x 35
x 8
Unread post by loeb »
Is there a way, using VBA, to identify the geometry (arc, circle, hole, etc) that a CenterMark is attached to? If that's possible, I'd then want to be able to get properties of that geometry, such as diameter/radius.
Thank you
by josh » Sat May 07, 2022 9:34 pm
Meh, I'll post it here too for posterity.
Dim swDwg As SldWorks.DrawingDoc
Dim swAnnot As SldWorks.Annotation
Dim swView As SldWorks.View
Dim swEnt As SldWorks.Entity
Set swDwg = swApp.ActiveDoc
Set swView = swDwg.GetFirstView
Set swView = swView.GetNextView
Set swAnnot = swView.GetFirstAnnotation3
While Not swAnnot Is Nothing
If swAnnot.GetType = swCenterMarkSym Then
Set swEnt = swAnnot.GetAttachedEntities3(0)
swEnt.Select4 True, Nothing
Set swAnnot = swAnnot.GetNext3
Wend
Answers: 11
x 19
x 456
Re: How to identify the "parent" of a Centermark?
Wend
